New Ford boss not wasting any time!
Originally Posted by Stealth
Good work union brother. I'm in the IAM&AW (international association of machinists and aerospace workers) local 776.
The only TRUE union comments come from a UNION worker. The rest is, well............ B-Something.
Kidding... kidding....
I'm also a Union member of Laborers Local 310 out of Cleveland Ohio and I stand very proud of my Union and stand up very strong for Unions. This country needs them!
Originally Posted by GIJoeCam
You raise some perfectly valid problems, but there can certainly be some very valid reasons those errors occurred that have absolutely nothing to do with the assemblers on the line.
<snip...>
If I'm new on the job, how the hell am I supposed to know that tere are supposed to be 4 bolts on that part? If there is no hole in the pan and no nut welded in place, why would I assume any different?
<snip...> As long as tab A fits slot B, my job is done and I've got another job in about 4 more seconds. I don't sequence the parts, I just install the parts that show up in the bin. It's not my place to question whether every one of the 500 other people did their job, I just need to make sure I do mine to the best of my ability.
And regardless of whoever put what part where, why wasn't this system tested for proper functionality before the vehicle left the plant? At the dealer, I looked at the vehicle for ten seconds and saw something was amiss. Or maybe it was tested, but the tester said "Whoops, this ain't working...well, it's not my place..."
Whatever happened to accountability for one's actions?
The installer does not test the parking brakes. The final inspector has a process to follow for that inspection, and generally that test happens on the chassis dyno at the end of the line. That's like saying that the assembler should test the water pump before loading the engine into the crate to ship to the assembly plant. Just doesn't work that way.
Yes, it should have been caught at the factory, but maybe the new guy or the substitute wasn't aware of that check. Maybe the regular guy for the job had to pee at an odd non-break time, and the relief man didn't regularly do that job and missed that check.
That's likely exactly what happened. The guy on the left doesn't see what the guy on the right is doing, and they're not working off a common build sheet. There's one on the left, and one on the right. It's possible that the sequencer stuck the wrong tag on one vehicle and there was another vehicle that came off the line with the exact opposite arrangement too. <snip...> Even if there's a sign telling you what comes next, you're bound to get mixed up once in a while. You do your best, but you're never 100%. It's not humanly possible.
The Mustang brake incident I related is one thing, how about the Grand Marquis that had leather seating in the front, and cloth seating in the rear. Somewhere along that line, somebody installed the leather seats in the front. Further on down that line, someone installed cloth seating in the rear. And somewhere, between when that second seat was installed and when the vehicle was loaded onto rail or truck or however they get to wherever they're going, someone saw that there was an obvious mismatch. Why wasn't anything said?
Maybe I'm misdirecting my comments towards the UAW and it's workers. Bottom line - I want to know why grevious errors slip through the cracks without no one saying a thing before the vehicle leaves the plant. Period.
<post snipped here and there due to length>
The installer just does what the tag says, or the sequencer sends. It's not the installer's job to question it.
Sure, someone might inqure if they thought it wasn't right, but how would you know? The sequencer sent a cloth seat, so the logical assumption would be that the sequencer did his/her job properly and sent the correct seat. Unless I have something that says it shouldn't be a cloth seat, I'm going to install a cloth seat. I may question it at the earliest opportunity, but I'm definately not going to stop the line to ask a question (the wrong mentality too, I know, but that's the way it is on an assembly line, union or not)
But, what about the guy at the end of the line that does the final inspection? What's his excuse?
Again, redunancies...what ain't caught at one point, I'm hoping that it'd be caught at another, and another, and another, and certainly before the vehicle is deemed fit for shipping - especially with an obvious error like mismatched seating.
I highly doubt this was something that happened from the factory. Keep in mind that once the vehicle rolls out our doors, there are a whole lot of other people that handle them before they reach the dealerships. An improper tie-down could easily cause those issues, and that's not the assembler's fault in the slightest. While you may have recieved tham in that condition, I'm quite sure ford didn't intentionally or knowingly ship them in that condition. Let's play devil's advocate here, and say you're right, though. The installation of a tailgate involves no less than 6 people that I can think of. One installs the hinges on the gate, one mounts the gate to the vehicle (or possibly a robot does), one fits said panel after it's been installed on the body in white, one fits the strikers, one fits the latches, one fits the motor/actuator, and one inspects the fit and finish after e-coat/paint. Keep in mind, none of those 6 people probably even see each other in the plant, and they do their jobs minutes if not hours apart from each other. It's not a simple process of saying, "Employee # 1365 didn't do his job right. That's why it's out of adjustment."
well, I'm glad Quintin thinks he knows everything as just being a guy behind a counter at a service desk at a Mercury lincoln dealership. He obviously has no idea what it's like to be on the line as these guys do putting cars and trucks together.
My uncle just retired from Ford 3 weeks ago after 30 years in, building engines for our F-150's, he worked very hard on the line for Ford, and no where are people as lazy as Quintin makes them out to be
UNION = SKILLED
Non-Union= Unskilled, un Educated
UNION = SKILLED
UNION = SKILLED
I was talking about Construction trade Unions on that comment I made. all Union Construction trade members must go through a 4 year apprenticeship school program.
Just don't take any offense when I don't take anything you say seriously, based on other dumbass things you've said and posted in the past.
It also doesn't change the fact that you're neither a UAW member, nor a Ford employee.
-Joe
(4th generation Ford employee, member UAW Local 600)
-Joe
Being a UAW or a Ford employee is not relevant to the reality of unions and how they continue to get smaller and smaller. It would not hurt any of the big 3 to cut lose the unions and it would actually make them more competitive, produce better quality vehicles and retain jobs here in America.
The fact of the matter is the big 3 will continue to move as much work as possible across the border to remain at least competitive. Their failure to do so will allow them to continue losing market share to the other companies, such as Toyota, who are more competitive and build better quality vehicles. Reality is reality and no matter how much some people may wish it away there is nothing you can do about it…
It is NO excuse that a “new” guy or “substitute” missed something and thus the reason a product went out as a defect.
If that is truly Ford and their Unions position then I know I will surly purchase a Toyota truck for my next truck since they do NOT allow for such ignorant excuses. Toyota is a true lean manufacture, of which Ford is not, and has processes, procedures and standards in place to insure such stupid mistakes are not made.
Ford, if there any kind of a world class manufacture has processes, procedures, and standards that should NEVER allow for such stupid mistakes as only installing 3 out of 4 bolts for a seat assembly. See Ford is not a lean manufacture, one of the reason they are failing so bad in the market, they think they are “kind of” lean but they really aren’t. It’s sad that a company such as Toyota, which is viewed as foreign, has to teach Ford how to manufacture a product correctly…
Originally Posted by 01 XLT Sport
Toyota…
You continue to babble on about the union, but it's all been said before, weeks, months, years, decades ago, so is there any reason for the continuous bagging of them?
I think not, but who really cares? I am ready to see some more threads of Mattineer's life experiences.
There are thousands and thousands of non-union workers working on government contracts. Law requires they get the prevailing union wage. Now if the Unions were to become extinct what would happen to these wages? So even though those non-union workers don't like the Unions they RELY on the Unions to keep those wages up there. If the Unions were to go under there would even be less job security. Wages will plummet. Everyone is affected by those wages if they disappear. Do you think a $10 per hour auto worker is gonna hire a plumber, roofer or electrician? What about stores and restaurants? I was in the suburbs of Pittsburgh this past May. It looks like a war zone. Everything was torned down, falling down or boarded up. It was sad to see knowing that it once was a thriving industry. Those non-union auto assembly line workers make pretty good money because of the Unions. But believe me there are people willing to do their jobs cheaper. No one is safe.
what u need is a nice Jap piece of junk called a Toyota which I'd be embarrassed to even drive any of there trucks as there girlie trucks with a Jap name on it..nuff said...
Go buy ur Jap truck and shut up man
