intake system
Recently, Testand Corporation conducted an ISO standards test on automotive air filters which can be viewed at this link: http://www.dieselbombers.com/chevrol...r-testing.html. All I can say is this explains in detail the reason for
(Arlen) SPICER wrote,
“Now that I am not doing the tests and my objectivity is not necessary, let me explain my motivation. The reason I started this crusade was that I was seeing people spend a lot of money on aftermarket filters based on the word of a salesperson or based on the misleading, incomplete or outright deceiving information printed on boxes and in sales literature. "
I would avoid oil impregnated filters. While they have their purpose in off-road applications, Ford/GM/Dodge all have “watch-out” bulletins where the oil has contaminated intake sensors. - they even have a training video for the techs on this (flatratetech.com) .
If you look at the flow data, WIX HP filters flow 98+% of K&N and have a much smoother flow post filter plus excellent filtering, for a fraction of the price! The OE’s have an excellent air intake system. What many view as an issue (is the plastic intake tube with its noise canceling design) actually increases air pressure. It is the same hydraulic concept used by fire fighters creating water supply where psi is low. By having the air cross the path at a 90 degree angle, the pressure is increased proportionally. Fire fighters use what is called a “4-way valve” or “Blake Valve” at the hydrant where the water is cycled through the fire engine (pump) and sent back into the valve crossing the water flow at a 90 degree angle. In this case it also acts as a sound canceling device! At low speeds, this can reduce the flow a tad (which is what most “feel”), but in terms of peak hp/tq, a good high flow filter is all that is needed. You can use a WIX OEM HP replacement filter in the OEM plastic manifold box and either remove the plastic tube and replace it with a piece of pipe/hose, etc or remove the tube completely and replace the tube by building an air ram type intake into the air box manifold (where the pipe use to attach)- make sure ti terminates above the fan shroud to avoid water intake or fan induced pulsations.
While a CAI may look cool, it only adds about 6-8 hp unless you have a custom tune. Plus, with the 2005, there is a large risk of running lean unless you have a custom tune. Forget the CAI, do the above mentioned mod and spend you money on a tuner. A tuner is the single best all around mod you can do for drivability and performance.
i agree with the above amsoil filter is the way to go i have a performance shop with my buds and thats all we would do if someone came in as well a tune is the best bang for your buck. do you like the sound of your flowmaster?
Hey again iam not sure I would buy a tunner
I would do some homework and find someone
close to you that tunes instead I think you would
Get better results instead of a plug in and play
Tuner. Just make sure its a tusted shop that
Knows what there doing that way they can
Restore your factory settings if your not
Happy
Just an idea
Happy
Just an idea
Happy
Just an idea
Happy
Just an idea
That is not saying you are wrong and I am right, just that I feel much better trusting my truck to someone that has spent years tuning these trucks. When they have the HEX code and a list of my mods, they know what I have and what needs to be done.
