high flow cats on 08 f150 question
Old Jul 28, 2012 | 03:43 PM
  #46
LincolnMarkLT20's Avatar
I love my high flow cat's from Magnaflow, I have my 02 sensor shut off with a custom tune. My truck is very loud and has a deep sound.
Old Aug 21, 2012 | 06:41 PM
  #47
jetpuck73's Avatar
I want to get them on my 05, which ones should I get?
Old Aug 21, 2012 | 07:56 PM
  #48
Originally Posted by Zander10893
I suppose I'll revive this thread. Can you just reuse the stock O2 sensors or would you have to buy new ones?
Yes you can re-mount OEM sensors. If any CEL issues, have your custom tuner update a file to turn rear O2 monitoring off.
Old Aug 23, 2012 | 06:24 AM
  #49
Zander10893's Avatar
Thanks Darren! High flows may just have to be the next thing on my list.
Old Oct 4, 2012 | 12:31 PM
  #50
mch0146's Avatar
so is having the o2 sensor after the cat any louder than having them inside the cat?
Old Oct 4, 2012 | 09:01 PM
  #51
O2 mounting does not effect the volume. The catalyst is not interrupted within either model by the O2 mount.
Old Oct 5, 2012 | 01:20 PM
  #52
mch0146's Avatar
so what about different brands like catco, walker, and dynomax? Or does everyone get magna flow cause everyone knows the name?
Old Oct 5, 2012 | 01:30 PM
  #53
Catco and walker are big names. Walker is a huge aftermarket oem exhaust company. Usually everything is direct fit. The cats we use ARE NOT high flow cats, they are just universal cats. I've done some research on this, you have to look at the cell count in the substrate to determine if they are high flow or not.
Old Feb 21, 2013 | 08:53 PM
  #54
F150Swartz's Avatar
so i have a question, i have an 05 with a 5.4. i had the same problem with magnaflow telling me i have four cats under my truck, which i do not. so will either setup work? the 4 cat or the two cat? whats better, will the two that everyone is mentioning on this thread work? would they be best? and how bout with headers? also i have to pass emissions test crap here so that may make a difference. thanks.
Old Feb 21, 2013 | 11:22 PM
  #55
fine_style150's Avatar
2 cats work, just like everyone else has re-iterated.
Old Feb 25, 2013 | 09:58 AM
  #56
iLL6031's Avatar
so some of the 5.4 have 4 cats? call me a noob but how would you know if you have 2 or 4 besides looking under your truck
Old Feb 25, 2013 | 11:02 AM
  #57
'97- and some '05's have 4 from then on its 2 cat systems.
Old Feb 25, 2013 | 11:38 AM
  #58
With headers depending on style, if longtube, you will need to run a 2 cat system. The front set of cats on a 4 cat system sit right where longtube header primaries sit.
As far as emissions, stick with a cat with a 300+ cell count.
Old Feb 25, 2013 | 11:52 AM
  #59
iLL6031's Avatar
cool ty
Old Sep 22, 2015 | 10:35 PM
  #60
Johnmorris72's Avatar
Just an inch or so. Not too close, not too far.
94106s are louder and cheaper ($67 ea. )since they're a smaller cat ( takes less stainless steel to make them ) The 94306s are 30% quieter than the 94106s and are T-304 stainless ( shiny ). All depends what you think you would more prefer, the loudest sound close to cat-less, or a louder sound but not too loud.
Can you run just two cats one for both sides I wanna run true duals out the back and needed to know if I need 4 or 2 cats
