1999 power windows
Old 06-08-2011, 08:29 PM
fordfanatic1990's Avatar
1999 power windows
I have a 1999 f150 with 112xxx miles. Just recently my passenger window stopped working it went down and would NOT go back up, I bought I new motor for it thinking that's what the problem was. Unfortunately it is still going up. Will still go down but not up. Drivers side works fine. I checked to high current fuse under the hood and it checks out good. My manual does not list any other window fuses. Anyone have any ideas.
Old 06-08-2011, 09:07 PM
SSCULLY's Avatar
did you check the pigtail from the switch to the motor for power ?
This is that 2 pin gray connector that is on the motor, the side you want to check is towards the switch.
Old 06-08-2011, 09:13 PM
no but it does not go up with either the passenger ms drivers side switch
Old 07-07-2012, 05:42 PM
shortee667's Avatar
i have same problem any suggestions
Old 07-07-2012, 05:58 PM
If it will not go up from either the drivers side or the passenger side, I would check for a broken wire behind the door panel. If the window dropped all the way down, you have a broken regulator, but if the window is still in it's track, has to be the motor or wiring.
Old 07-07-2012, 06:04 PM
What year is your truck? Also, check the index here under Electrical. This is in our Articles and How To section.
https://www.f150online.com/forums/ar...-articles.html
Old 07-07-2012, 06:06 PM
shortee667's Avatar
not really sure what to do.dont know diddly sqat about how to take of door panel. someone can tell me how and wat tools required i will give it a shot truck is 1999
Old 07-07-2012, 06:35 PM
Found this, see if it helps.
http://api.viglink.com/api/click?for...13417004932651
Quick Reply: 1999 power windows
