Announcement from PHP
Old May 28, 2009 | 02:20 AM
  #46
onefitty's Avatar
The X3 is probably your best bet, then you can get a scan gauge seperately for fairly cheap and have the three custom tunes and the gauge pod too. Hope this is some help.
Old May 28, 2009 | 08:00 AM
  #47
Ah, 88racing - I'm going to post a "wait a minute" here. According to everything I've seen PHP post, they are NOT upgrading any existing pre-2004 Edge units until they get the cable problem resolved. They are continuing to support pre-2004 Gryphons.
It may seem wrong not to upgrade an Edge if the user says he has a good cable, but, what if they DO upgrade it and then discover there's a "cable fault"? I think the "hard" cutoff until the cable issue is resolved makes the most sense.
So, if you have a Gryphon already, you're golden. If you have a pre-2004 Edge and are having problems, contact Edge. If you have a pre-2004 Edge and want to upgrade to a Gryphon, stand by. If Edge works out the cable problem, you'll be able to do it. If you can't wait, look into getting an X3.
- Jack
Take it easy Jack I edited my post. Sorry for the mix up. I thought the upgrades were still good because those cables were not having any problems.
Old May 28, 2009 | 09:51 AM
  #48
JackandJanet's Avatar
I wasn't excited, 88 - I just wanted to avoid any possible misunderstanding that would cause hard feelings later.
- Jack
Old May 28, 2009 | 10:01 AM
  #49
It really was a "hard" cut off!
I will keep promoting the xcal3 along with the scangaugeII xgauge then! Until the problem is taking care of.
Old May 28, 2009 | 10:42 AM
  #50
Fordahaulic's Avatar
Not to add fuel to the fire or anything, but the Scan Gauge acually looks like a great product.
From what I've read on it last night, it looks to have all the capabilities you'd possibly want to display along with a compact size.
This looks to be a great addition to all X3 owners out there that want to display the trucks data in real time.
Old May 28, 2009 | 03:53 PM
  #51
31 YNOT's Avatar
to bad its fugly
Old May 28, 2009 | 05:25 PM
  #52
Blue02FX4's Avatar
hmmm... not a big fan of the scangauge.... im thinking about sellin my edge and getting a livewire with customs on it.
Old May 28, 2009 | 05:45 PM
  #53
What's the matter with scangauge?
Livewire is huge compared to the edge. The mounting options are nothing compared to the edge pod.
Old May 28, 2009 | 10:42 PM
  #54
Blue02FX4's Avatar
dont have my edge in the pod anyways.... gets in the way of the defrost. how big is the livewire? and about the scangauge... im nost sure if i could read it or not... looks really short and small with long spread out numbers...
Old May 29, 2009 | 12:18 AM
  #55
1BAF150's Avatar
88, I was startin to lean a little towards that way too, seems like its our only option for a dash mounted, easy to read display and still have custom tunes..
Whats everyone think? Livewire with custom tunes? Good deal?
And btw, is it just me, because whenever I go to PHP's website and try to click on the Xcal3 link, its actually not a link, the mouse just passes over it, while everything else on that page is a link to more info on the product...strangeee
Old May 29, 2009 | 03:15 AM
  #56
Stephen87's Avatar
Well looks like I am going to have to wait a little while longer to get the Gryphon oh well I Guess if I waited a while already I can wait a little while longer especially if the product is as good as I read.
Old May 29, 2009 | 11:37 AM
  #57
Shouldn't be hard to see even with bad eyesight! And much better mounting options too boot. IMO
Old May 29, 2009 | 11:38 AM
  #58
Picture's a bit fuzzy also
Old May 29, 2009 | 03:23 PM
  #59
From my research the lw's mounting options were not appealing to me. Suction cup to the windshield or a screw in pedlestool mount to the dash. No one could provide me with dimensions and from every picture I saw it looked big. It does have some cool features like up to 6 pids displayed at a time where as gryphon/edge/scangauge are only up to 4 pids. Also has a shift light but why do you need you need one in an automatic?
Old May 29, 2009 | 04:11 PM
  #60
Veteran: Army
what if you're manually shifting when you race but using it as a normal automatic for normal driving
