Why NOT k&n
Originally Posted by dzervit
Apples to Oranges... it's not the same as an enclosed AF1 pulling the same cfms.... and the volant design just looks like it's packed with restrictions.... your killing me.
From the testing that Mike T did, the AF1 is the quietest CAI available and also the one that gives the most power gains.
That's what XLT is trying to get across... it DOESN'T exsist... but if it DID, odds are very high it would outperform the open-element designs.
And 'quietest' is subjective. The AF1 is not even close to quiet. It has the worst moaning and groaning from 2-3.5K RPM I've ever heard. Horrid. If my AF1 is the quietest on the market and produces WOT noise of 93db + then I hate to hear the others...
See I had an open element (conical) K&N on my Infiniti SUV and never had a loud moaning noise. Just a grunt when it sucked in air when I punched the gas and then it quickly was gone. There was an extremely low hum, and by that I mean that just having a quiet conversation with the person next to you and you couldn't hear it. This is why I have doubts that the AF1 is the quietest on the market. Best performing but unlikely the quietest.
Quiet is subjective, quietest of the SAFE CAIs is not.
Originally Posted by Superchips_Distributor
Any low-restriction intake is going to give a little bit more noise when accelerating at full-throttle at any rpm, and on any vehicle. The Air Force One is the best and the quietest in this regard, by far, and I do not see that as being an issue in these smooth & quiet vehicles. All the other intake kits are significantly louder, especially on part-throttle where you do 99% of your driving, where you want what is called "intake moan" the least - so I heartily recommend the AF1.
Originally Posted by hwm3
Since it doesn't exist you can't possibly KNOW that it would produce any power gains. You can believe that it would, and think that it would, but not KNOW that it would.
I use the cliche, "It's like comparing apples to football players" and people give me a weird look.
Haha.
Originally Posted by jpdadeo
It’s simply a bogus theory. Surely you don’t think it hasn’t been tried; tried and failed is why you don’t see all the CAI manufactures doing it because horsepower sells at any price.
Now, like Mike said and proved, at speed the difference in engine baby temps and ambient air temps are so close the point is moot. That's why manufactures don't do it, it's not worth it. The AF1 and others are good for upper-end power when the engine needs all that air, that is were the biggest gains lie and where the advertising goes. They don't care if they can make an extra 3 ponies down load when the maximum power gain is in the upper RPM range... that boils down to marketing.
This isn't complex as defusing a nuclear bomb for pete's sake. Simple engine principals! Sheesh! Cooler air = more power and if you can deliver cooler air ANYWHERE in the powerband you'll get more power. Uhg. Stop the insanity!
Last - why we see such larger power gains form properly designed intake kits on the 5.4 3V F-150 is precisely because of the design of the *factory* intake kit - not because of materials used, though the Air Force One does indeed show factual advantages in IAT's. The stock intake is far more restrictive in most (but not all) rpm ranges in the 5.4 3V F-150 than in previous F-150 designs, and is why we see such huge gains possible at just 2000-3000 rpm, but the power gains actually DROP at 5000 rpm, up at the power peak - because *that* is the only area where the stock factory 5.4 3V intake works decently - and in that area, we see maybe 10 HP gains from the Air Force One, while we see 25 HP gains at the wheels at just 3000 rpm from the Air Force One on that application. That weird anomaly is due to the design of the factory intake - the expansion chamber invokes a pressure drop one air velocity hit s critical point, and that allows it to not cost too much peak HP up top, even though it costs a boatload of HP down low - they're simply trying to keep *velocity* up along with dramatically retarded cam timing in their effort to provide some torque as well as try to improve MPG in the 5.4 3V F-150. There's *far* more going on there than most will ever know in the 5.4 3V F-150's air intake tract design & PCM calibrations, etc, it's fascinating - and can be improved on quite a bit, as we all know - that's what we do.
In fact, we recently did testing on Marc Carpenter's 2004 5.4 3V truck and showed that compared to the stock factory intake, which uses the cold air inlet in the fenderwell and is made of the black phenolic resin-based plastic, at IDLE, in heat-soak conditions, the AF1 intake showed a DECREASE in IAT's of about 6-8 degrees that continued for over 10 minutes at idle.
so should i fabricate a pipe that sends cold air from my a/c to my intake so that when i want more power all i do is turn it on MAX A/C? wish i had known all this before i purchased my af1
MORE oxygen per square inch of air EQUALS more HORSEPOWER. It is NOT a theory it is FACT. What do you think NOS does? It’s basically compressed cold air that expands into a gas state and provides MORE oxygen per square inch over ANY air intake system there is. When using NOS you have to insure to feed the motor PLENTY of fuel because if you don’t it will lean out and blow up.
What I have been stating is not theory but FACTS easily proved by some studying, research and perhaps a few simple internet searches…
While a few extra seconds of cold air may not mean much to a street driving normal F150 it can make the world of difference in the ¼ mile. Look at JohnnyLightning's Lightning, it has a box to shield it from the motor compartments heat.
Johnny runs 10’s and I believe a few 9 second runs in his Lightning and has done a TON of testing. So you can beat if shielding the open element intake did not provide a few extra tenths in the ¼ mile the box would not be there…
If you look at any of the 10, 11 or 12 second Lightning’s you can just about bet you will not find any open element air intakes like the AF1. You will either find complete cold air intakes or open elements with the box shielding them from power robbing heat generated in the engine compartment. These guys know this from “real world” testing in the ¼ mile…
