How-To: Push-button Start (2004-2008)
Old Feb 14, 2011 | 02:37 PM
  #166
fordfenatic09's Avatar
That's pretty sweet! I'm looking forward to the write up
Old Feb 14, 2011 | 06:20 PM
  #167
panda24619's Avatar
i wanna do this. what color are the wires for my year? i know its an expedition but it should be the same as the f150 of the same year.
Old Feb 14, 2011 | 07:51 PM
  #168
Originally Posted by squirtbottle09
Im in the middle of mine as well. I took a different aproach. I did not gut the cig lighter and the only thing I had to cut was the orange part off of the housing. I stuck the button in just far enough to when the lighter is pressed the coils of it press the button. It makes it a bit easier to fabricate and requires less cutting. The wiring up is just the same.
This is the part that you stick the actual lighter in. There used to be a orange connector on the back of this. I cut it off with a hacksaw and drilled the hole out big enough to stick the button through.
Here you can see the lighter actually in the piece. You can see that I left the lighter in tact completely.
I then installed the push button far enough back so that the lighter can be placed in place. But when you actually push the lighter in it depresses the button down. So it looks just like a regular sig lighter. You can even take it out and show people that it is just a normal lighter
Shows it inside the plug.
I used some wireties on the shaft of the starter to make sure that it didnt back off. I just used to included hardware to make it tight.
I did not wire it up tonight because it got dark. Tomorrow I will accomplish that tast including the squirt mod (valet switch) and will get pics of that as well.
Thanks again OP.
And I dont see why the wires would heat up any more than they already do now.
Where did you get your button? And how much? Thanks
-Frankie
Old Feb 14, 2011 | 10:15 PM
  #169
Ford12508's Avatar
So I have the remote start, so obviously a momentary push button wont work for me. I put in a rocker switch and I left it in the "ON" position so that I can use the remote start in the morning. Will I see any issues leaving the switch in the "On" Position? I also put in a couple of momentary switches right next to it. Thanks for that, now I got the idea in my head that I need a NO2 set up in the truck
Old Feb 15, 2011 | 03:13 AM
  #170
panda24619's Avatar
does no one know what wires it is for the 97-03 f150 or 97-02 expedition? and would this work as a switch? i have one laying around. http://www.google.com/imgres?imgurl=...t:429,r:11,s:0 cause if not ill go buy a real starter/horn switch.
Old Feb 15, 2011 | 01:36 PM
  #171
Yeah that should work, as long as it can handle the amps, and from what I've read, it is the blue/green, and the red/blue wires coming from the ignition. Just remove the access panel under your steering column and the panels from around your steering wheel, grab a multimeter and start testing if they don't seem to match the descriptions. Happy cut/splicing
Old Feb 15, 2011 | 01:45 PM
  #172
Check out page 7, somebody else was having some troubles/questions about the same thing and it seems to have been resolved there. Hope it all works out
Old Feb 15, 2011 | 02:09 PM
  #173
panda24619's Avatar
how many amps is it? i dont think the switch can handle it. ill just buy the big one. cause its SOOOO exspencive! but okay ill look. i gotta take the dash apart now! then ill post pics on how i did it!
Old Feb 15, 2011 | 02:42 PM
  #174
Yeah, I do believe a 15A switch should handle it, just check the ignition fuse, whatever it's rated at should be plenty for your switch. Thanks, I'm looking forward to seeing the finished product
Old Feb 15, 2011 | 03:05 PM
  #175
panda24619's Avatar
well first i gotta find time. gotta do some stuff and buy the switch. they should have it at o'rielys right? ill most likely do it this week. i want to be the only expedition with a push start button!
Old Feb 15, 2011 | 03:53 PM
  #176
yeah they should have something that'll work, but you won't be the only one, there's a few guys with them on here already.
Old Feb 16, 2011 | 02:44 AM
  #177
panda24619's Avatar
on their expeditions? lame! o well. at least ill be the only one in SD with one! haha i found out my little button switch can hold 16As. will that be enough? if not i found a starter switch i like that can hold 60As but its $10. haha
Old Feb 16, 2011 | 07:24 AM
  #178
yeah, they have em on their expeditions, and yeah 16 amps oughta do it, I have a 15A. I just got mine all fabbed up last night, I'm wiring it in today
Old Feb 16, 2011 | 03:14 PM
  #179
panda24619's Avatar
okay let me know how it goes. and i think im going to do it later today. or at least take apart the dash. still not sure where yo put the button. maybe in my center console.
Old Feb 16, 2011 | 06:30 PM
  #180
Just got mine all finished, I'll take pics this weekend and get 'em up so you can see how I did it
