Saleen Tailgate
Old Sep 13, 2008 | 04:25 PM
shaunakadub's Avatar
Saleen Tailgate
Anyone know if it's possible to pick one of these up?
I don't know if its just a panel to go over the existing tailgate or you have to get a new tailgate, but I want one... bad.
I can't find anywhere that mentions if it's for sale.
Old Sep 13, 2008 | 05:13 PM
Hespen537's Avatar
Well, if I had to take any guess, your local ford shop might be able to order you one. It should be a match up as long as your year is specified.
Old Sep 13, 2008 | 05:34 PM
illness95's Avatar
i doubt its a whole new tailgate.. rather a plastic peice that is attached to the stock tailgate..
john1102's Avatar
or call saleen
Old Sep 15, 2008 | 09:13 AM
Yeah it may be a plastic cover.
Old Sep 15, 2008 | 11:15 AM
Raptor05121's Avatar
looks cool. kinda reminds me of the styling from the 95 year tailates.
Old Dec 17, 2008 | 04:48 AM
Kathoga's Avatar
I can tell you for certain that it is a new tail gate. I had to have mine replaced due to a defective pin when I picked up my Saleen in DEC. The tail gate has about 20 connector holes in it for the black piece to attach to.
Old Dec 20, 2008 | 11:56 PM
BayouSupercrew's Avatar
The top plastic is more spoiler like than a stock f150 too, just saw some tonite to verify.
Old Dec 22, 2008 | 11:01 AM
Ag Lightning's Avatar
Wrong. My panel just arrived on Saturday from Saleen. It's a fiberglass panel that is mounted to the tailgate with about 8 bolts. You just simply have to drill the holes and attach the nuts through the access panel on the inside, top of the tailgate.
The part is not cheap though. Paid $189 without the shipping
Old Dec 22, 2008 | 08:42 PM
jhogan20's Avatar
Ag Lightning, I got mine today too. Did you get application instructions? I didn't and wanted to make sure I was applying it properly. Let me know if you can help me out. Thanks
Old Dec 23, 2008 | 05:22 PM
No, no application instructions. All you need to do is remove the tailgate from the truck, remove the access panel located on the inside top of the tailgate, center the Saleen panel on the tailgate, mark for your holes and drill. I used a 1/2" drill bit and was quite successful. Once you've got the holes drilled and everything lines up, apply the supplied 3M on the bottom of the Saleen panel (I also applied a thin bead of the 3M emblem adhesive all the way around the part for good measure.
Lastly, apply the panel to the tail gate and install the tailgate back on the truck. Once you've got the tailgate on, you can now screw on the washers and nuts through the access panel. To save you some time, the nuts are 10mm
Simply snug down without over tightening and your done! It does help if you have a small, SKINNY, pair of arms and hands... The two nuts at the bottom are VERY hard to reach.
Hope this helps
Old Dec 23, 2008 | 08:33 PM
expedition4x4's Avatar
anyways to answer shaunakadub's question... there's one on ebay for auction starting at $219 with free shipping... here's the link http://cgi.ebay.com/ebaymotors/Salee...ehicleQ5fParts oh and you should check these out too http://cgi.ebay.com/ebaymotors/Salee...3A1|240%3A1318 http://cgi.ebay.com/ebaymotors/Salee...Q5fAccessories
Old Dec 24, 2008 | 11:22 AM
jhogan20's Avatar
Thanks for the help
Old Dec 26, 2008 | 01:30 PM
jhogan20's Avatar
I requested this from Saleen if anyone else needs it.
Old Dec 29, 2008 | 02:00 PM
Kathoga's Avatar
As I said... New Tailgate. Surely anyone can hack up, drill, grind to get anything to fit on anything.
Sorry... Mine came with the holes already prepared.
Good luck. Hope it turns out how you want it too
