problem with system.
Old Apr 17, 2009 | 12:10 AM
  #151
jrfonte's Avatar
that drawing was correct for a dvc 4 ohm sub you cannot wire it like that for a dvc 2ohm. that speaker will work but you will only get 300 wrms out of your amp. and you will have to wire it in series amp positive to speaker coil # 1 positive coil # 1 negative to coil #2 positive coil #2 negative to amp negative. wire it like this so it will be a 4 ohm load on your amp if you wire it like the drawing you showed above it will put a 1 ohm load on the amp and your amp will shut down.
Old Apr 17, 2009 | 12:47 AM
  #152
JJDH's Avatar
Originally Posted by ltz400racer
nvrm, i found it on that site you showed me!! is this the correct setup for it?
just double checking, thanks
man i hope this fixes it!
i gave you that site!!! didnt mean to interrupt
Old Apr 17, 2009 | 01:00 AM
  #153
ltz400racer's Avatar
haha i know you did! and i actually learned alot!! thanks for that link..
anyways, so it will look like this?
i drew this up very quickly, i am a visual person... just makin sure im understanding this "NEW" languange
basically what your saying is tht in the long run, i will need a 4 ohm load coming from the sub... while connecting the DVC together...
Old Apr 17, 2009 | 01:19 AM
  #154
jrfonte's Avatar
yes if you are goingto use that sub that your buddy has the 2 ohm dvc. and whatever you do dont just connect 1 voice coil again
Old Apr 17, 2009 | 01:21 AM
  #155
ok cool..
now to find a decent ground... hmmm
Old Apr 17, 2009 | 02:58 AM
  #156
jrfonte's Avatar
all you need is a bolt that you can put the connecter under and tighten it down just make sure it has good clean bare metal no paint if you want you can check the resistance with your meter to make sure its good run a wire up to your negative bat terminal and probe with the other meter wire till you find a spot that has low resisitance close to 0 ohms with your meter set at 200 ohms.
Old Apr 17, 2009 | 09:27 AM
  #157
Allright. Ill have to do that meter test. I thought my ground was good. It was connected to the jack bolt in the body of the car..
Old Apr 20, 2009 | 07:05 PM
  #158
xBRAAAP's Avatar
This happened with my system as well. Do your subs move out and in when it does the strange "bump" noise? If so, your amp is shot- I blew a M.A. Audio 1200watt amp and it was doing the same thing.
Old Apr 20, 2009 | 10:00 PM
  #159
jrfonte's Avatar
he has a 4 ohm dvc 10" sub and the sub shows 1.5 ohm on one of the coils i think its safe to say its his sub he had 2 different amps and they both did the same going into protect with the sub connected and did what there were supposed to when the sub was disconnected.
Old Apr 24, 2009 | 01:28 AM
  #160
would there be a way that i can wire this sub with a 2 ohm load? its the Kicker Comp VR 2ohm DVC....
Old Apr 24, 2009 | 02:18 AM
  #161
jrfonte's Avatar
if you only used 1 coil you could but you remember what happened last time you did this right? lol
1 ohm or 4 ohm is the only thing you will get out of it.
Old May 2, 2009 | 01:00 PM
  #162
well, my system is finally fixed.. and it sounds great! thanks to everyone who put all of their time and effort into helping me sort all of this stuff out...
i have one more question... is it bad to turn up the gain, bass boost and stuff on the amp?
Old May 2, 2009 | 02:24 PM
  #163
JJDH's Avatar
http://mobile.jlaudio.com/pdfs/gainSetting.pdf
Old May 2, 2009 | 02:36 PM
  #164
thanks
