problem with system.
Old Apr 16, 2009 | 07:09 PM
  #136
JJDH's Avatar
Originally Posted by ltz400racer
doesnt it need to be a 4ohm single voice or a 2ohm dual voice?
what if he adds a second sub, wouldny 4 ohm be best
Old Apr 16, 2009 | 07:13 PM
  #137
ltz400racer's Avatar
i know this is extrememly off topic right now, esp since my system still isnt working, but since im searching for a new sub, i figured i would ask if a capacitor would make the system sound better, or run more efficient
Old Apr 16, 2009 | 07:18 PM
  #138
http://www.kicker.com/compvr
is this sub ok?
  #139
JJDH's Avatar
No
dont even worry bout that NO is the answer, they are a great boat anchor though
Old Apr 16, 2009 | 08:08 PM
  #140
could you wire two subs to the single channel amp? wouldnt it cut down on the power? i would love to run two subs!
Old Apr 16, 2009 | 08:19 PM
  #141
JJDH's Avatar
of course u can put 2 subson a mono amp. with two 4 ohm svc subs your impedience would be 2 ohms, u have to ;ook at ur amp to see what it puts out at that level
Old Apr 16, 2009 | 08:23 PM
  #142
what do you mean by what it puts out at that level
Old Apr 16, 2009 | 08:30 PM
  #143
JJDH's Avatar
how many watts the amp can produce with a 1,2,4,or 8, ohm load
Old Apr 16, 2009 | 08:32 PM
  #144
JJDH's Avatar
add this to your favorites, it is your new friend .....http://www.bcae1.com/
Old Apr 16, 2009 | 08:43 PM
  #145
jrfonte's Avatar
no capacitor unless you want something for target practice or just want to pay alot of money for some pretty led lights and a voltage gage.
your kicker kx 600.1 puts out 600w rms at 2 ohms. to run i sub 600wrms get a single voice coil 2 ohm or get a dual voice coil 4 ohm. to run 2 subs get 2 single coil 4 ohm subs rated around 300w rms , or 2 subs dual voice coil 2 ohms 300 w rms each
Old Apr 16, 2009 | 08:49 PM
  #146
so would that sub i posted earlier, the kicker compvr
heres the specs:
Size (IN.,CM) 10, 25.4
Impedance (OHMS) 2 or 4 DVC
Max Rec Amplifier Power (WATTS PEAK/RMS)* 800/400
Sensitivity (dB 1w/1m) 85.5
Frequency Response (Hz) 25-500
Mounting Depth (IN.,CM) 5 9/16, 14.1
Mounting Cutout (IN.,CM) 9 1/4, 23.5
Min Rec Sealed Box Volume (CU. FT., Liters) 0.8, 22.7
Max Rec Sealed Box Volume (CU. FT., Liters) 3, 85
Min Rec Vented Box Volume (CU. Ft., Liters)** 1.25, 35.4
Max Rec Vented Box Volume (CU. Ft., Liters)** 1.75, 49.6
Old Apr 16, 2009 | 09:17 PM
  #147
jrfonte's Avatar
yes that would work but get the dual 4 ohm coil model
Old Apr 16, 2009 | 10:14 PM
  #148
how do you wire the dual coils with one channel
Old Apr 16, 2009 | 10:23 PM
  #149
nvrm, i found it on that site you showed me!! is this the correct setup for it?
just double checking, thanks
man i hope this fixes it!
Old Apr 16, 2009 | 11:57 PM
  #150
well, it looks like the sub im getting is the dual 2 ohm voice coil, a buddy of mine has one he is giving me for 30 bucks.
will that be a problem?
