New Member/Project Thread (04 FX4)
Old Jul 16, 2015 | 02:48 AM
  #46
04FX4Kev's Avatar
Sungear and sungear shell. These are quite problematic on F150s. Typically, these are stripped when there is no reverse on the truck (from what I've read).
Another Youtube picture. This is what normal wear and tear looks like. As you can see from previous pictures, the sungear shell on my transmission is in perfect condition.
Old Jul 16, 2015 | 02:55 AM
  #47
04FX4Kev's Avatar
Here is the planetary gear assembly
Planetary gear assembly removed
Old Jul 16, 2015 | 02:58 AM
  #48
04FX4Kev's Avatar
Third gear drum
Third gear drum removed and picture of the reverse band
Left - Kevlar reverse band (new) Right - old oem reverse band
Old Jul 16, 2015 | 03:00 AM
  #49
04FX4Kev's Avatar
Everything apart
All done. All parts have been swapped out up to this point. Reassembly in reverse. Transmission pump reinstalled.
Will be spending all day tomorrow for remove and replacement of my current transmission.
More updates to follow.
  #50
04FX4Kev's Avatar
Originally Posted by fordabbits
I admire your willingness to go all in without experience. I'm sure you did some research but a tranny is something I would gladly pay to get rebuilt lol
Thank you. It was a lot of work. July 20th or 21st will be my 2 month anniversary of owning the truck.
Old Jul 16, 2015 | 10:52 PM
  #51
mitymerc's Avatar
If the trans lost reverse... most likely the reverse band is broken. Its common on the F-150s
https://www.f150online.com/forums/tr...times-two.html
Old Jul 18, 2015 | 11:12 PM
  #52
04FX4Kev's Avatar
Rebuilt another transmission that I purchased used. Came from an '07 F150 Lariat (4x4) with only 120,000 km
Old Jul 18, 2015 | 11:14 PM
  #53
04FX4Kev's Avatar
Transmission is now inside. There was a component from the front pump of the transmission that was installed backwards which prevented the transmission from fitting in. All resolved now. Shifts good in all gears. Reverse seems a little tight but maybe it needs to be broken in. Pictures below
Old Jul 19, 2015 | 05:29 PM
  #54
04FX4Kev's Avatar
Jacked up
Rear driveshaft removed
Getting a heat shield removed in this picture
Old Jul 19, 2015 | 05:46 PM
  #55
04FX4Kev's Avatar
Transfercase removed
Old Jul 19, 2015 | 05:50 PM
  #56
04FX4Kev's Avatar
Had to remove this fan in order to manually turn the crankshaft.
Pictures of the engine bay with the fan removed
Picture of the oil filter (thought it was interesting). Oil change done less than 500 km ago.
Old Jul 19, 2015 | 05:53 PM
  #57
04FX4Kev's Avatar
Missing a few pictures as hands were extremely dirty/greasy and wanted to get the transmission removed ASAP (about 4-5 hours in now).
Transmission jack mounted
Transmission out (Left = rebuilt Right = original)
Build date sticker of the original transmission (July 27, 2004)
Torque converter from the original transmission.
Old Jul 19, 2015 | 06:03 PM
  #58
04FX4Kev's Avatar
Original transmission on the workbench (pan and plate removed)
Removed the connector (as my rebuilt one was broken) and replaced it on the rebuilt one.
Old Jul 19, 2015 | 06:05 PM
  #59
04FX4Kev's Avatar
Haven't stripped down the original transmission but as you can see in the pictures, first signs of damage are apparent.
Broken snap ring
Old Jul 19, 2015 | 06:08 PM
  #60
04FX4Kev's Avatar
Made sure that everything was torqued to the correct specs
New filter and pan gasket installed
Levelled the surface of the pan
Pan installed
Rebuilt torque converter installed
Ready to be installed!
