What did the heavy duty trailer package give me?
Hi there everyone.
I have a 2007 F150 5.4 3V Lariat and just discovered that the original owner purchased the optional heavy duty trailer towing package.
My question: What all did this give me over stock? can my truck pull more weight? Does it effect my launch speed?
Does anyone have the Specs?
Thanks Guys.
Thanks Guys.
I'm pretty sure the tow package is just the 4/7-pin wiring connector, Class IV receiver hitch, and aux tranny cooler. There could be an upgraded radiator, but I doubt it. Gear ratio is independent of the trailer package, so you could have 3.55, 3.73, or 4.10's with the trailer tow package.
It was, however that has nothing to do with the towing package. The HD truck was available with the 7-bolt wheels, and I think just in XL/XLT trim levels. It gave the truck another 1-1.5K lbs or so extra payload due to the axle and std 4.10 gearing. I've only seen them personally on the reg cab long bed models, but I'm pretty sure they offered the HD package on other cab configurations.
Thanks for the input everyone.
I kept doing additional research by way of a Ford dealor supplied with my VIN #. I discovered I actually have the 3.73.
Additionally, I found this for any other 07 guys out there:
http://www.fleet.ford.com/resources/...guideApr08.pdf
Which should be the standard trailer package for any 4.6/5.4L. Is there a normal trailer tow package that doesn't include some of those items? Seems odd to call it an HD Towing package if there's not a non-HD towing package.
I guess Ford assumes all of their trucks can tow/haul from the factory but this option allows for longer durability resulting from better cooling. Not to mention it is ready to go right from the factory with the beefed up receiving hitch.
In any event, I always thought the battery was abnormally large; but I love it as I can/have run pretty much anything and everything off this battery.
Again, check out this link: http://www.fleet.ford.com/resources/...guideApr08.pdf
It details all Ford towing specs from that year including what I have... the "535" option.
I don't know about 2008 but in 2010 trucks, the standard tow package gets you a five? channel trans cooler instead of a 9 channel. I think std tow package uses a lighter hitch (bumper hitch?) as well.
You need to get the 2008 spec sheet and read it CAREFULLY. Both tow packages include a lot of the same items but the ones in the MAX tow package should be heavier duty so you'd have to get into the detailed specs to find out.
BTW I think MAX tow also includes heavier rear (and front?) springs, at least starting with 09 models.
