Mag-Hytec Trans Pan and Diff Covers
Old Dec 18, 2009 | 10:08 AM
AAK625's Avatar
Question fdh
fgd
Old Dec 18, 2009 | 04:05 PM
sbchris's Avatar
I've got both. The double deep trans pan should be used with a good fluid to see best results. The magnetic dipstick and drain plugs are both great features. Would I do it again, yes!
Old Dec 18, 2009 | 06:52 PM
mSaLL150's Avatar
I'm gonna grab one of those trans pans shortly. My buddy has one and says it greatly reduced temps on long trips, something my truck really needs.
Old Dec 18, 2009 | 08:42 PM
FX4life's Avatar
I never saw the need for the trans pan, and if I got one it would purely be for the drain plug. I have heard they do wonders if you tow all the time. However, I have been on several long trips in recent years and never saw my trans temps peak over 168, even in the summer, so I just don't see the need. Right now in winter they are in the 150's normally.
I do have a diff. cover and love it, especially with a big lift and 4.88 gears I wanted that extra fluid and the ability to change it quickly. In 3 years of service I have had zero issues with it and have changed the diff fluid 3 times since installing it, each taking less than 15 minutes. Plus it looks really good!
You can't go wrong with Mag-Hytech's stuff its top notch
Old Dec 18, 2009 | 11:31 PM
LightningJMP's Avatar
FX4Life, how much fluid do they require? I just ordered one and want to go ahead and order the fluid for it.
Old Dec 19, 2009 | 12:37 AM
AAK625's Avatar
When I regear for the 35's I may want to grab a couple of these, I suppose.
Old Dec 19, 2009 | 01:50 AM
FX4life's Avatar
They hold 5 Quarts total
Old Apr 8, 2014 | 04:44 PM
metalica9's Avatar
With the mag hytec pans is anyone using the provision for the temp sending unit. I was told its on the back of the pan where the cross member is. I have only an inch between the pan and the crossmember. I have a 05 F150 4x4 with the 5.4. Seems like to me there wouldnt be enough clearance.
Old Apr 8, 2014 | 05:47 PM
ak_cowboy's Avatar
The transmission has a test port on the drivers side that you can put a temp sender in. You don't have to use the one on the pan
Old Apr 8, 2014 | 07:25 PM
s27payne's Avatar
Originally Posted by metalica9
With the mag hytec pans is anyone using the provision for the tempo sending unit. I was told its on the back of the pan where the cross member is. I have only an inch between the pan and the crossmember. I have a 05 F150 4x4 with the 5.4. Seems like to me there wouldnt be enough clearance.
I have both the trans pan and diff cover, and a temperature sending unit on both. Autometer sending unit, 1/4 inch FIP threaded if I recall correctly. Clearance is not an issue.
Old Apr 8, 2014 | 07:57 PM
s27payne's Avatar
I just went out to truck and took a quick look. I do see what you are talking about with the clearance on the backside of trans pan, it is extremely close to the close member. However.....the sending unit unit mounts on the front on the pan not the rear.
Here is a pic of each:
The pictures are rotated 90 degrees clockwise. Front of vehicle is towards the bottom of each picture.
Old Apr 14, 2014 | 07:53 AM
metalica9's Avatar
Thanks for the info and the picks. I actually talked to someone at mag-hytec and they told me it was in the back. Apparently they have no idea which end I'd the back even after describing the pan to them.
Old Apr 14, 2014 | 09:40 AM
EricRenner's Avatar
Anyone happen to know the filter number for the deeper pan ?
Old Apr 14, 2014 | 01:29 PM
FX4Frenzy's Avatar
The 4R70W-DD from Mag-Hytec uses this filter part number:
http://mag-hytec.com/store/index.php...products_id=63
I bought my 4R70W-DD trans pan direct from them and it included the correct filter for that pan.
Old Apr 14, 2014 | 02:10 PM
EricRenner's Avatar
thanks
