Recon Clearance Lights Installed...w/ lots of Pics....56k Warning
ended up finding something that worked though. a plastic spatula and an entire bottle of rubbing alcohol. The doors pristine finally.
Thanks though
Caseyh46 light bar mod It's not on my truck anymore. Someday I will get around to mounting my lights behind my grill
Those are the OEM Ford TTT mirrors... before they were making the newer SuperDuty style they are making now. They basically are the same as the ones Schefenacker makes, only the lens cover for the marker/signal lights is clear instead of amber. Here's an article trytokeepup did on them
Thanks for the thread, it looks great!!!. I have been thinking about these lights since the first day I bought my truck. My truck is levelled with 33" tires so it sits higher than some trucks that have the lights stock, so I don't think it'll look bad. With the smoked lens, it would almost blend in with the black...hmmm....
Tylus, lookin good. Not my cup o tea on a half ton, but they still look good.
When are you gonna come do mine then?
Looks really good!! I have installed a set on my buddys 04 Dodge 2500. He was so nervous that he couldn't hold the drill steady so I drilled them for him.
If you get a chance i want to see what these look like off at a distance. Maybe 50 yards or something. Like others have mentioned, you may have created the latest "I HAVE TO HAVE THOSE!!" mod on F150online. Nice Job.
jrbhc8
jrbhc8
jrbhc8
I don't think this will work on a solid white...or solid red truck. The black would look out of place IMO. Best I can say is to try and test fit 'em. You know they'll sell if you're not happy with the look
nothing has worked so far
I've tried Goo Gone, Alcohol, WD-40, fingernails, heat, friction
I get an 1" at a time. Then I get frustrated and walk off
Youtube Video of my lights at night
http://www.shop3m.com/62466749306.ht...KU=60980033892
