LOOK MOM, NO KEY!!! – ford2004f150, STARTER BUTTON INSTALL!
Old Aug 20, 2007 | 01:29 AM
  #61
AKAO1029's Avatar
Do you have to have a remote start system or can you install this mod even w/ out having a remote start system cuz having a push button start is pretty baller status and would love to do that to my truck?
Old Aug 20, 2007 | 01:47 AM
  #62
Josiah's Avatar
I've been meaning to get a remote start I'm going to rewire it so I can start the truck without the key in the ignition (still cannot drive it, just start it). I will take a video of my new Z1 when I get it, and the push button start as well. At the moment I've wired my push start ignition to start only with the key in the ignition.
Old Aug 20, 2007 | 02:05 AM
  #63
mindgame's Avatar
Nice Mod...
Question.. What happens if someone keeps pressing the button or does not remove it. Are you screwed if that happends?
Old Aug 20, 2007 | 02:24 AM
  #64
Josiah's Avatar
Depends how you wire it, I wired mine right up to the ignition wire which has an anti grind feature built in.
Old Aug 20, 2007 | 03:59 AM
  #65
07HD's Avatar
I would like to see somebody rig up a system like the cars in europe have. As long as your keys are in your pocket all you need to do to drive is press the start button. Same with door locks, they unlock with the keys being in your pocket once your near your vehicle. Now that would make a start button worth having.
Old Aug 20, 2007 | 03:16 PM
  #66
neuspeed5's Avatar
Yep. My 335i has that feature. But, as cool as it is, all cars are starting to have it. It's kind of like fender vents...once they started putting them on the new Buicks again, they lost their cool factor.
Old Dec 27, 2007 | 01:54 PM
  #67
azmidget91's Avatar
well i installed my ca671 yesterday and just bought a s2000 button today, cant wait to get it and put it in
Old Dec 27, 2007 | 02:07 PM
  #68
Cadmaster's Avatar
Now that is cool.
Old Dec 27, 2007 | 07:14 PM
  #69
Cadmaster's Avatar
Originally Posted by ford2004F150
The Honda S2000 requires you to put the key in BEFORE YOU CAN start it with the button, like Josiah's push button mod.
THIS MOD you can start it WITHOUT the key, JUST NOT drive it anywhere. This boosts up the coolness factor of the mod.
Also - it will only run for 15 mins and shut off, IF it was ever left running for whatever crazy reason.
That is not correct. I have driven the Honda's with the push button. As long as the key is in your pocket you can start and drive the car using the push button.
Old Dec 27, 2007 | 07:21 PM
  #70
j_nann's Avatar
awesome mod!!
Old Jan 3, 2008 | 05:19 PM
  #71
azmidget91's Avatar
ok i just got my s2000 button, but not sure of which pins i use? i know if it were going to a regular starter relay pin 1 would go to the relay pin 2 goes to power and pin3 goes to ground
but you said you only used 2 wires ground and then the ground pulse to the alarm, which wire went to which pin?
Old Jan 3, 2008 | 06:35 PM
  #72
Josiah's Avatar
He said only 2 wires, but clearly he has it hooked to 12v, as the light cannot operate off ground. I think he was just referring to his trigger wires. Google "S2000 starter install" and you'll find a diagram of which pin does which.
Old Jan 3, 2008 | 06:56 PM
  #73
azmidget91's Avatar
yeah i looked at several diagrams and its just that they were all positive output not ground like needed on the code alarms, i had tried a few different variations of the wires and couldnt figure it out but i finally got it
yeah i figured he had to have a 12 for the light, but not sure how he did that unless if i wired it different then him because i wired mine up by making the following connections, pin1 to ground(diagrams online show this as the output pin) pin2 to the alarm(and this one is for power) then the third pin online they say is for ground.....maybe hook pin3 to 12v?
btw here are a few pics
Old Jan 3, 2008 | 06:59 PM
  #74
Josiah's Avatar
it should be a ground pulse to the blue w/white stripe wire if I recall correctly, that is if you have the CA-670. I'm about to wire mine up, so I'll too have to figure it out.
Old Jan 3, 2008 | 07:02 PM
  #75
azmidget91's Avatar
yeah a ground pulse, basically it needs to be grounded just for a short time, and i have the 671 which is basically the same as a 670 just newer
