LOOK MOM, NO KEY!!! – ford2004f150, STARTER BUTTON INSTALL!
Originally Posted by Copeland!
Install pics?
Originally Posted by GB150
Do you have remote start on your truck? If so then all of your reasons are mute because you can start the truck and your wife can roll the windows up/down, use heat or ac if you use the remote start.
I wonder how insurance companies will feel about this mod...
Actually, I get an insurance discount for this alarm…
Originally Posted by 4x4whiteSTX
thats sweet, although i have a question, it says 7 levels of security and the first one is you cant steer without the key in the ignition so if there if your keys are in your pocket and you start the engine, then can you steer? or are you just starting the truck to warm it up?
The security is - IF someone started it they CANNOT drive it without the key in. Locked steering! I am starting for reasons I listed already.
Originally Posted by Josiah
Nice. But am I mistaking or can a stranger start it if the doors are unlocked?
Also, it pages the fob when it starts... so I know, ya know?
Plus, I can disable it with the hidden “kill switch”, IF I am leaving the truck in a non-secure environment.
How bout this one MOM
No key and No key cylinder.
Toggle switch is for accessory and when you hit the start button it latches on the ignition. When you shut off the toggle it shuts everything down. Theres a ca-640 set to 30sec start kill so the button doesn't do anything after 30 secs unless you hit the disarm. And why's that shifter sticking straight out of the dash??
Originally Posted by RamSS/T
The way I see it is you have to put the key in he ignition, switch it on...then reach over and push button start it. Where as all you had to do factory was put the key in the iginition and crank it.
Cool...you have actually complicated the process.
In the past I have read your "comments" in threads.
Most all of time I had some faith that you HAD some smarts... I am going to write it off as you "pretending to know" how to read.
Watch the VIDEO!
Pay close attention, THERE IS NO KEY IN THE IGNITION!
Everything was clear as day in the first thread. I am using Code Alarms 670 to START THE TRUCK WITHOUT THE KEY IN!
I am hoping your smarts aren't as counterfeit as your Mark LT.....
Originally Posted by runnerboy
video doesnt work for me
Originally Posted by ford2004F150
WTF?
Watch the VIDEO!
Watch the VIDEO!
Originally Posted by kashifordf150
Yes, but is there no steering? So you still have to put the key in the ignition to drive it, correct?.
But IF a stranger could just jump in, start it, and drive off... then it wouldn't be very secure then, would it? Hmmm...?
Pretty dumb to put a start button in without some kind of security to it.
Then ANYONE could steal it!
If you're going to do this modification, I guess that is the way to do it. On the car that this is made for do you have to put the key in, or is it fully functional?
THIS MOD you can start it WITHOUT the key, JUST NOT drive it anywhere. This boosts up the coolness factor of the mod.
Also - it will only run for 15 mins and shut off, IF it was ever left running for whatever crazy reason.
Also, it is functional when I need to run into the corner store I can press the button (while the truck is running w/ key in) it will engage the ignition, so it stays running, then I can REMOVE the key and it will STAY RUNNING. This allows me to run in and back out of the store (on those hot or cold days) without turning off the truck or leaving the keys in it. I can lock and arm it with the key fob too.
WTF?
Watch the VIDEO!
Watch the VIDEO!
