Converting Column shift to center console shift?
Old 02-13-2007, 04:47 PM
etrevino103186's Avatar
do you have to use that base part to connect the shifter or could I make a "box" No one has a price on the shifter?
Old 02-13-2007, 11:51 PM
05HarleySD4x4's Avatar
Originally Posted by 05RedFX4
If you're thinking about this swap, make sure the truck has the E.S.O.F. 4wd system, otherwise that stick coming up thru the floor tends to get in the way.
In other words, is?
Old 02-13-2007, 11:58 PM
Originally Posted by 05HarleySD4x4
In other words, is?
electronic
shift
on the
fly
Old 02-14-2007, 10:23 AM
ericd's Avatar
Check my flow-thru gallery. There are a ton of pics showing how the swap is done.
If your dash is staying the stock grey, it's pretty easy to do. Since I wanted my trim pieces Medium Pebble to match my interior, it was a bit more of a headache.
As for the cost - I was never brave enough to add everything together. If I had to guess, I'd say somewhere in the $500 to $750 range.
If you have any questions, feel free to contact me anytime.
E...
Old 02-14-2007, 12:27 PM
electronic
shift
on the
fly
ah i thought it was a bit more complicated than that. I would defenitly need 4x4, and im not too crazy about the manual shifter 4x4's. Thanks for the info!
E...
Awesome, thanks for the info! I would defenitly have gray/black interior with this next truck. I did see some center consoles with the shifter in them already on ebay for around 100 bucks. Does that seem like a good deal? One would think you could do this mod for under 400..
Old 02-14-2007, 03:01 PM
ccla's Avatar
Would be tight for 400. My console cost 60.00 dash was 150, trim pieces so far 110.00, still need shifter, shifter cable and radio trim
Old 02-14-2007, 05:41 PM
shookman34's Avatar
I did that swap on my other 05 F150....if I recall, I paid about $160-$185 for the shifter (new)..about $40 for the shifter cable....bought two consoles of ebay for about $45 each (one to mount in truck, and one for fill in pieces between console and dash. I also bought the fill in piece to cover the hole where the column shifter was, but I don't remember how much it was. If you have electronic 4X4, it's actually not that hard...just search for the threads where the guys posted the pics of how to do it. The hardest part for me was getting the nerve to drill the hole in the floor board for the new shifter cable to run through.
Old 02-14-2007, 09:01 PM
Thanks alot for the info guy, it all helps!
My first choice is going to be a f-150 with the center console and shifter, but if i cannt find one i will defenitly be doing this mod.
Old 02-14-2007, 09:24 PM
harleydude04's Avatar
haha, same way with my ranger being on ranger-forums!!!
it used to be stock....
Man that is a !@#$ sweet *** ranger for sure. Nice work!!!
Old 02-14-2007, 09:55 PM
InCuBuS's Avatar
i did this mod too but mine was a little more pricey. i had tan interior and i transformed it to black interior so id say with the roush leather, black panels console shifter, and dash i spent 2500 bucks. still got the doors to do and the headliner. ill get some pics up. i thinks theres some in my gallery
Old 02-14-2007, 10:03 PM
Originally Posted by InCuBuS
...i spent 2500 bucks. still got the doors to do and the headliner...
Old 02-14-2007, 10:11 PM
05RedFX4's Avatar
F.Y.I. to get the flow thru console and shifter on a 4x4 you need to get an FX4 (scab or screw only) or LARIAT they are not available from the factory on any other model.
On a 2wd the only come on an FX2 and LARIAT.
Keep in mind though, the flow thru shifter combo is OPTIONAL they are not standard equipment, even though most have them.
Now FX2's, Harley Davidson's and King Ranches get them standard, but they are special edition models NOT trim levels.
Old 02-15-2007, 12:16 AM
with new seats, dash, carpet, that isnt bad even tho it sounds like alot. plus you could sell all your stocker pieces and make some back
Old 07-01-2019, 09:51 PM
Brendan Willson's Avatar
Mounting brackets
Originally Posted by scorpio333
Here's a pic from some time ago:
Looks like you could do this with the floor 4x4 shifters, guessing it's gonna be tight though.
Check these, long and some great pics, last one has some schematics:
https://www.f150online.com/forums/sh...d.php?t=216615
https://www.f150online.com/forums/sh...d.php?t=218003
https://www.f150online.com/forums/sh...d.php?t=219437
https://www.f150online.com/forums/sh...d.php?t=219283
https://www.f150online.com/forums/sh...d.php?t=217537
How do you install the mounting brackets to bolt thr console down?
Old 07-02-2019, 11:13 PM
You do realize this thread is 12 years old?
Quick Reply: Converting Column shift to center console shift?
