Factory Navigation System???
Old Nov 30, 2006 | 10:13 AM
  #76
SpeedyRacer's Avatar
Originally Posted by ozcar2
So the area where the Nav unit screws in used to be all plastic (i.e. the old radio sat on top of the plastic, and the screw went through the plastic?)
Yes.
Old Nov 30, 2006 | 10:58 AM
  #77
SmoothSL's Avatar
Well, it turns out I don't need Mark's service.. The truck I was getting got damaged in their wash and prep stage so they ended up getting another truck from another dealer with the Nav in it.. I read the manual online and it says something about voice recognition, but I see no button on the 07 Lariat... Am I missing something?
Old Nov 30, 2006 | 11:26 PM
  #78
anyone have the part number for the OEM GPS antenna? Let me know ASAP, Thanks!
Old Nov 30, 2006 | 11:27 PM
  #79
ozcar2's Avatar
Excellent! Thanks Speedy.
Do you have the factory Audiophile subwoofer in your truck?
Old Dec 1, 2006 | 08:55 AM
  #80
04LARIATXCAB's Avatar
I'll check my antenna tonight the part number should be written on it.
Old Dec 1, 2006 | 08:24 PM
  #81
Part# 7L3T-10E893-AA
Old Dec 4, 2006 | 09:01 AM
  #82
ozcar2's Avatar
Am/FM antenna Adapter
In order to install you'll need an antenna connector converter, Metra Chrysler Antenna Adapter (40-CR20)... somewhere in the stereo forum they wanted me to get a 40-CR10 which is WRONG, the 40-CR20 is the right adapter you'll need.
So, to put a 2007 factory Nav unit in a 2006 F-150, I will need to get an AM/FM antenna adapter?
Is this what I will need???
http://www.circuitcity.com/ssm/Metra...oductDetail.do
Old Dec 4, 2006 | 10:24 AM
  #83
That is the one I needed for my 04
Old Dec 4, 2006 | 11:35 PM
  #84
Yes.
Thanks Lariat for the PN!
Old Dec 7, 2006 | 07:17 PM
  #85
ozcar2's Avatar
NAV antenna location
Which side is UP on the NAV antenna? I assume the black plastic piece faces up and not the metal piece?
How have you guys been fastening the antenna, and to what?
Old Dec 7, 2006 | 07:28 PM
  #86
Thats how I have mine oriented. I used a plastic zip tie to secure it to the metal frame near the top of the dash. I'm not sure where the factory was mounting them but I haven't had any reception problems.
Old Dec 7, 2006 | 09:35 PM
  #87
oreokid220's Avatar
Nothinbutaford-
I am very interested in this item. Do you include a GPS disk or where and for how much can one be obtained? Also does this unit work like other aftermarket units where it can play DVDs or be made to play DVD's? How do I go forward in making the purchase from you?
Old Dec 8, 2006 | 02:14 PM
  #88
oreokid - the factory nav system will NOT play DVD's, it is solely a DVD-Ram drive. if you need a disk for testing purposes i can mostly likely make a copy for you. to be legal you only can use it for 'testing'.
Old Dec 8, 2006 | 04:23 PM
  #89
these guys have a solution for playing DVD's on the Nav:
http://www.tvandnav2go.com/
Old Dec 9, 2006 | 10:41 AM
  #90
oreokid220's Avatar
Ok the website there i cant really open but it appears they make a product that will allow an external source to play through the factory navigation. Does anyone have experiance with this or better yet has anyone been able to get their factory unit to play dvds?
Thanks again everyone.
