Power Folding Mirror Install on F150
Old Aug 6, 2005 | 09:02 AM
  #91
2001SUPERCREW's Avatar
Originally Posted by vigness
Copied the diagrams for the door locks the other day, will stop in and get the diagrams for the PFM system this weekend.
On getting the door panels off the '05, pretty easy, just the screws at the bottom of the door and the two behind the inside handle. The only thing you need to remember is to pop the bottom speaker mounts after taking the speakers out, they will keep the panel from lifting up.
Will you get the one for the relay I need to know what pin is ground.
I have everything in place I just need to know that info.\
I checked with 2 dealers about the PM switch, both say that the KR is the same as the rest, can you check that out aswell.
thanks Tim
Old Aug 6, 2005 | 01:57 PM
  #92
vigness's Avatar
???? Window handle... that means you have manual windows. Not sure on those, mine are elec. Usually there is a clip on the back of the handle, you can pick up the tool at the parts store, it doesn't look like much for the price, but it is WELL worth the money.
Old Aug 6, 2005 | 05:03 PM
  #93
Ascii's Avatar
thanks Tim
Pin one from this diagram it is the pfm module ground.
Old Aug 6, 2005 | 05:06 PM
  #94
I know that, the problem is what is ground on the relay the numbers do not match on the Ford relay.???
thanks
Old Aug 6, 2005 | 05:10 PM
  #95
Ascii's Avatar
They should thats the 2005 f150 pfm module.
Old Aug 6, 2005 | 05:11 PM
  #96
Ascii's Avatar
are you using just a regular relay or a ford 2005 pfm module??
Old Aug 6, 2005 | 07:47 PM
  #97
jztbcz's Avatar
Excellent ....
Old Aug 6, 2005 | 10:45 PM
  #98
the ford PFM relay
Old Aug 6, 2005 | 10:46 PM
  #99
Well since the pic shows round circles you can't tell what is what.
thanks tim
Old Aug 7, 2005 | 12:07 PM
  #100
Ascii's Avatar
well the ground is the only thick wire it's 12 gauge and the rest are 20 besides that it's the black wire. If you have the module in hand there should be #'s inside the disconnect on the plastic too.
Old Aug 7, 2005 | 12:41 PM
  #101
I have a 2005 f-150 that did not come with the PFM so I would not have the plug, that's why I'm asking for the info I need to know what blade on the PFM relay a (Ford one) is the ground......
Old Aug 7, 2005 | 01:04 PM
  #102
Ascii's Avatar
Look inside ontop of the blade there are numbers @ least there are on the power window modules. Or buy the harness for 30 bucks.
Old Aug 7, 2005 | 01:12 PM
  #103
If you read it above I allready said that the numbers do not match.
Thanks for the help I will get the info somewere eles.
Old Aug 8, 2005 | 07:40 PM
  #104
vigness's Avatar
I may have found the key to using the factory wiring!!!
Went in to the dealership and copied several wiring diagrams. When I got to the power folding mirror, there was two pages that looked almost identical, so I copied both.
Notice I said ALMOST.
On the second page it says "If equiped" but doesn't say what it might be equiped with. In the middle of the diagram is a connector not on the other diagram... with a jumper! From C2108 pin 3 to C2059 pin 3 between S503 and S603.
I have to get one diagram I missed on the DTR relay box ( there's TWO relays for that bad boy besides the resister ) and will see if I can find the location of the connectors
Old Aug 8, 2005 | 09:40 PM
  #105
Ascii's Avatar
the pfm module has 2 relays in it are you sure you aren't looking at that?
Also what i see is c2108 is a ground that connects the heater the light (on the mirror) and the turn signal.
Is that c2059 or c2095 ? since i cant find a 59.
