basic tune-up procedures?
Old Feb 8, 2011 | 12:51 PM
Gotts2BMe's Avatar
I take it you got your trans issue figured out? what was it?
Old Feb 8, 2011 | 05:29 PM
Bansheeman6100's Avatar
T-case selector was mis-aligned internally. a bit of violence fixes everything in the long run
Old Feb 8, 2011 | 08:49 PM
and are there any other plugs that are good that dont cost an arm and a leg?
Old Feb 9, 2011 | 07:03 AM
MGDfan's Avatar
Yep.
OEM Motorcrafts - either single or double-plat.
You do however, get what you pay for. I'm also reluctant to recommend NGK's. Here's why:
https://www.f150online.com/forums/601215-post2.html
https://www.f150online.com/forums/2300211-post3.html
https://www.f150online.com/forums/2076879-post9.html
Any plug manufacturer that can't tightly control heat ranges are not on my Christmas card list
MGD
Old Feb 9, 2011 | 12:29 PM
Motorcraft SP479's are $2.36 each at rockauto.com.
Old Feb 9, 2011 | 02:10 PM
See, I'm really likin that more than the $8ish for the Bosch's. Even if there is a difference, I doubt it's worth 4x cost
Old Feb 9, 2011 | 02:13 PM
openclasspro#11's Avatar
i put the oem plugs in at 100 k miles, just installed third set,ZERO issues,and thats anti-seizing em and torqueing them to 29 ft lbs, 302,000 trouble free,hard miles
Old Feb 9, 2011 | 03:15 PM
Raptor05121's Avatar
nice looking truck
Old Feb 9, 2011 | 03:39 PM
Originally Posted by raptor05121
nice looking truck
thanks!
Old Feb 9, 2011 | 08:46 PM
well i ordered the Motorcrafts, and will be doing a coolant flush/fill next week as well. just gonna do 50/50 mix. also fininshed up and got my Efan working. and think im gonna hold off on replacing the brake fluid, from what i've read theres not much of a point. but my power steering is making noise so that one i will do. just gonna fill it up with DEX/Merc. and debating on doing the O2's. i need to do it, but also need to get my Mustang up and running and the time/money im dropping on the F150 is taking away from that
Old Feb 10, 2011 | 08:43 AM
jimanderson's Avatar
PSA - Change your brake fluid
Ohh no you didn't go there, let me climb up on my soap box:
This is one of my pet peeves for ANY vehicle.
Yes in my race car the brake fluid gets changed a few times a year because it sees severe duty. In a daily driver please change it every 2 years.
In my wife's daily I neglected to change it at the 2 year mark, it went 30 months and was the darkest nastiest crap.
If you tow or use your truck I'd go with once a year.
Brake fluid is cheap insurance, a 1 qt bottle of Valvoline DOT3/4 is around $10
Off soap box
Old Feb 10, 2011 | 09:01 AM
MGDfan's Avatar
Off soap box
^^^ 100% agree.
Danged hydrophilic fluids!
MGD
Old Feb 10, 2011 | 10:48 AM
Well that's why I started a thread, thanks guys! I read in anoter thread here it wasn't necessary. Now I need to dig up how to totally drain the system and what the total capacity is
Old Feb 16, 2011 | 07:50 PM
well just replaced the power steering fluid with Valvoline Maxlife MERC. the fluid that was in looked red, but was very dirty. my squeak isnt gone, but is much better. and the fuel filter i picked up seems to be a bit longer and narrower than whats currently on the truck. Motorcraft part# FG986B F89E9155AA
will that work ok? and best way to replace all the brake fluid? figured just bleed them dry, then fill and bleed again?
next up: radiator flush and fill, Gatorback belt, spark plugs
Old Feb 17, 2011 | 09:34 AM
Do not bleed them dry - keep the reservoir full while bleeding or you will have a hell of a time getting the air out. That's the correct fuel filter.
