seafoam
Minorly. If your able to in a suitable area, instead of reving it out try to drive a little, speeds up the process of exhaling it, saves gasoline, and looks awesome running down the road, pre-tend its got 1,000 horsepower and you stomped the gas
Phew, I did the Sea Foam treatment on my '04 5.4-3v and after the waiting period, I drove it. It ran a little rough at first, and then seemed to clear its throat at one point and the check engine light came on. At the same time though it was smoother. I brought it home ater and disconnected the battery and the light stayed off after that. What code does anyone think gets thrown as a side effect of the sea foam? I didn't go get it scanned as I wanted to try the battery trick and see if it was temporary.
I can't remember exactly, but the O2 sensor throws a code for reading bad air or something of the sorts. Since you eventualy get good air running back through it, once it is reset with the battery disconnect you are good to go.
Like I said, don't take that as the gospel, it is just what I can remember.
Any engine treatment/cleaner that requires the battery to be disconnected because it caused the PCM to set a code and turn on the CEL, isn't something that should be used. The engine can be kept clean by changing the oil and filter at the recommended intervals, using a good high quality fuel and replacing the fuel filter regularly.
This is all it takes to keep a modern engine clean.
