Will this rim/tire combo fit???
I've finally gotten around to replacing the tires on my truck and i figured that since im going to be spending money maybe a new set of rims is in order. Specifically the 18" xd chrome monsters with some nitto trail grapplers. The specs are listed below...
Front and Rear
Offset: 35mm
Backspacing: 6.37"
Bolt Pattern: 6-135
Rec. Tire Size: 275/65-18
Weight: 28.4lbs.
Finish: Chrome Plated
Construction: 1 Pc.
Finish Warranty:
Manufactured in China
I was thinking that the tires could be 285/65/18.
Basically my question is will this set up work without any issues?
Im also open to any other thoughts about this set up or suggestions about alternative set ups.
Thanks for the help!
Front and Rear
Offset: 35mm
Backspacing: 6.37"
Bolt Pattern: 6-135
Weight: 28.4lbs.
Construction: 1 Pc.
Finish Warranty:
Well do u tow a lot? With the 295/70/18 (34.5 inch tire) it will effectively higher your gear ratio and lower your mpg a little. They would look great indeed, but negatively affect towing. The 285/65/18 will have no issues at all. If u want a little wider tire, they make a 305/65/18 that equates to 33.6x12 that would be a happy medium. Here's a good tire conversion site.
http://www.1010tires.com/TireSizeCalculator.asp
They have that 305 size on discounttiredirect.com
Yep. Would agree with u on that. My 17s tuck in like those would on yours and I like it. Not a fan of tires that stick out a lot more than stock. Those will tuck nicely. Guess I should say that the 305 tire I was referring to isn't made in the trail graps, but other manufacturers do.
Ive been doing a bit of research and ive noticed that there arent any people i can find running a wheel with 6.37" bs and 35mm offset. Is there a reason for this? Ive seen lots of people with the 18x9 monsters running 5.71" bs and 12mm offset. Is the set up i have going to look off or is there nothing to worry about???
I did and after playing arund a bit more on tireracks website i discovered a drop down box that had 2 more choices with different offsets and backspacing. I'm now thinking that the 18mm offset 5.7" bs is a good choice. Most people here seem to be running that set up with little to no problems. Any thoughts as to how the chrome monsters are going to look on my ole girl?
305/45/22 or I believe some are running 285/60/22. Believe bfg makes a tire in the second size. U wanting the biggest that will fit or closer to a 33?
