Rotor time, slotted
Rotor time, slotted
I just replaced my seized & piston cracked front drivers side caliper today, discovered the back of the rotor was grooved to hell, so its replacement time. I have done a lot of studying on brakes since my initial brake enhancement of Wager TQ Ceramics last fall after buying my new 33s, and I just spend an hour researching ten pages of rotor upgrade threads and I have an even better view on things.
I'll begin by explaining my needs/expectations. OEM replacement should be fine, I do not tow a lot, barely at all anymore. I do not need to stop from 120mph to 0 in 10', I just want to replace with good durable rotors that will enhance braking slightly, and last me until I trade in years down the road. I also HATE seeing my rusty rotors after washing the wheels, dont want to see this if its possible.
Now questions:
From my research, I believe I want the Power Slot rotors, debating on Cryo treatment of not. Any input from those with basic and cryo treatment?
I found them with prices on SummitRacing. $130 for a front disk slot set seems fair, $160 for the Cryo does too if the Cryo treatment is really that much better. Where is the best place to purchase either?
I have the ceramic TQ pads currently, the stock rotors look decently fine, so fine I may only replace the fronts for now with new pads. Are the ceramics good for aftermarket stronger rotors? Or is it the same deal that semi-metallic is better for rotor durability on non towing/racing vehicles? If this is the case, I may consider the semi-metallic TQs this time around, but I have no grooving problems ( or dust! ) with my ceramics. Also considering the Hawk pads since they are spoken and appreciated as much as the TQs. Any good feedback here?
I'm also going to bleed/flush the entire system when I replace the front rotors. Motorcraft fluid? Or is there something people prefer more?
So my plan is Power Slots (cryo? ) and semi-metallic TQs. Or should I re-buy the ceramics for tougher rotors? How about these 'dimpled' slot rotors that look pretty, do they hurt the pads any?
Feedback for other rotors is welcome, durability against salt, rusting, and warping is what i'm after. Do not suggest any drilled rotors to me because I do not need them, just dimpled if anything.
Darren.
Now questions:
Darren.
I think you know my opinion, too.
I know you really like the ceramics for lack of brake dust, so here's a theory for you: If cryo treating is not snake oil and does provide better thermal hardening / resistance to the rotors, they may be able to handle ceramic pads better. Then again, I don't really know enough about cryo treating to say for sure, so you'd be a guinea pig if you wanted to try it out.
I don't think anyones ignoring your post, I just don't think there's been a lot of talk about cryo around here. As for Power Slot rotors, they have a great rep and don't think you can go wring with them. The whiole slotted and cross drilled, and any other rotor debate has been discussed many times with varying opinions...search around a bit.
My stock brakes had about 25k on them before i replaced them.
The rotors were rusty, pads threw out so much dust i was cleaning my wheels atleast once or twice a week and the brakes squeaked and squeeled terribly it was driving me nuts.
A few members recommend power slots and hawk pads. they didnt have the cyro at the time, so i went with the regular powerslots.
after i installed the pads and rotors i noticed the braking distance improved, less brake dust, ( i clean my wheels every few weeks now) and just a better overall feel in the brakes.
When they need to be replaced I def will be going with power slots again.
What is your opinion on dimpled rotors effect on pads? Do you think they would cheese grade against the pads similar to how it is possible with drilled? Or are the drilling dimples edges well enough to be smooth as deep as they go?
If you have the extra doh to spend i would give the cyro's a try
Still debating the ceramic pads with Cryos, or just get the semi-metallics.
Hey, hey...
I just put the Power Slot Cryo Rotors on the front of my truck.
I've learned, (and I am still trying to figure a few things out) so maybe you can avoid the same mistakes that I made.
First off, my experiences are with my RWD so for you it may be different, I honestly don't know.
On the positive side...
Pre-Installation: See the hubs
Is this stock, for the 4WD guys?
Final Product
Overall, I'll much happier once the Pulsation issue is resolved. While I do notice an increase in performance, I feel as though for as much money as I've spent on this project I wish everything was working smoothly.
I hope that this helps you avoid some problems that I've had.
Good luck with the project mate!
Edit: Forgot to mention that the Hawk Pads are ceramic.
Final Product
