best pricest 35 or 37 inch tires?
Old 10-24-2008, 03:14 PM
grantoser's Avatar
If I end up getting a 6 inch lift for my truck, what are the best priced tires (35 to 37 inch) i should get with 20 inch rims? thanks so much.\
(BTW i know i spelled priced on the title wrong sorry haha)
Old 10-24-2008, 03:29 PM
fx4 for life 79's Avatar
a 35" tire would be cheaper
Old 10-24-2008, 04:10 PM
wandell's Avatar
You can usually find great prices on Nitto Terra Grapplers and they are an excellent tire.
Old 10-24-2008, 04:12 PM
07fx4silver's Avatar
Gonna need more then 6" of lift for 37's. Stay with 35's if you want to keep the price down, and I'd recommend 18's instead of 20's for 35's. Also, tires aren't the area you want to skimp on
Old 10-24-2008, 07:46 PM
mattd17's Avatar
17" tires and wheels are MUCH cheaper than an 18".... i know, weird since it has more rubber, but its true. that is why i just switched from 18's to 17's.
Old 10-25-2008, 01:46 AM
grantoser's Avatar
yeah i already have 20s and i wouldnt be changing them. So tires look pretty expensive and the cheapest lift i can find is 1200. So idk if thatll work out. haha. we'll see!
Old 10-25-2008, 05:30 AM
Fifty150's Avatar
Think again. If you current wheels do not have the proper amount of backspace, then you'll be changing them. You can't just get a lift kit, and then put on any wheel you want. They have to fit.
Old 10-26-2008, 06:27 PM
grantoser's Avatar
well what would the proper backspacing i would need be? would eagle alloys series 026 fit?
Old 10-26-2008, 06:33 PM
grantoser's Avatar
PART # SIZE FINISH PATTERN OFFSET BSM CAP # LOAD SHIP WT.
Eagle Alloy Wheels Series 026
0266-0964 22x9.5 Chrome 6 on 4.5 +14 mm 5.761 3174-06 2100 lbs. 46 lbs.
0266-0966 22x9.5 Chrome 6 on 5.5 +14 mm 5.761 3174-06 2100 lbs. 46 lbs.
0266-0973 22x9.5 Chrome 6 on 5 +40 mm 6.785 3174-06 2100 lbs. 46 lbs.
0266-0994 22x9.5 Chrome 6 on 135mm +40 mm 6.785 3174-06 2100 lbs. 46 lbs.
0266-2864 20x8.5 Chrome 6 on 4.5 +14 mm 5.264 3174-06 2100 lbs. 40 lbs.
0266-2866 20x8.5 Chrome 6 on 5.5 +14 mm 5.264 3174-06 2100 lbs. 40 lbs.
0266-2873 20x8.5 Chrome 6 on 5 +40 mm 6.288 3174-06 2100 lbs. 40 lbs.
0266-2894 20x8.5 Chrome 6 on 135mm +40 mm 6.288 3174-06 2100 lbs. 40 lbs.
Quick Reply: best pricest 35 or 37 inch tires?
