BFG AT KO 305/65/18 or 285/65/18
Thanks! I'm going to order tomorrow. I have the AS 2.5 kit on, so I'll go w/ the 305's. I found them at Discount Tire Direct for 282.00 ea. Does this sound reasonable, or are there other less expensive places to get these? I live in Olathe, KS near Kansas City. Thanks for your help!
Those 305's will look good on your truck. Duplicolor sells a paint made for wheels. If you prepped them right, they should look good. Not sure how it will hold up though.
http://www.youtube.com/watch?v=z3s4nMR0yxk
_________________________________________
Eibach Pro Truck 2/4 Drop,GF Shackles, 5,000k HID, HD Grill, 22" Boss 330's, 305/40/22 Kumho STX's
Those tires will be fine on an 18x9 wheel as well. You just need to be concerned about wheel backspacing (to avoid rubbing issues) when you go to a wider wheel.
Thanks fellas for your feedback. I did find a 305/60/18 on Discount Tire Direct for $287 ea, but it is a special order tire. As long as the 305/65/18's will fit, I'll go that route. Now just to decide on the wheels. Any thoughts on the Rockstars or Pro Comp 7005's in black?
