Tire pressure monitor system
this is my first thread, i just signed up and cannot find any thread on the Tire pressure monitor system. I just got a 2.5 inch leveling kit, with Moto Metal 951's with **** Cepek F-C II 33x12.50's and my tire pressure light is coming on in my dash. Is there a way i can turn this off, or fix it? I know i dont have the sensors thats on the stock rims. Any input will be helpful. Thanks.
To 'fix' it, buy new monitors and straps. Then have the dealer register the monitors with your vehicle. Cost probably in the $4-600 range. I don't like this either. I have 2 sets of wheels/tires and will be in the same boat.
So far I have done searches and have not found any way to disable it. Still looking.
The only way I have thought of so far is build a metal box that can be sealed and pressurized. Put the monitors in it and stuff it under the seat. Would love to find a setup like that.
My Toyota has a tire pressure monitoring system, but you set the desired pressure by depressing a button. The trick is to set the tires at the OEM recommended pressures, then depress the button to "capture" the pressure. Any deviations will trigger the alarm.
That being said, you should be able to correct for different tire sizes/pressures by resetting the "default" tire pressure. I'm not familiar with the Ford pressure monitoring system (n/a on my 05), but I'd be surprised if they didn't have a similar feature hidden somewhere. Perhaps even future programmers could solve this issue.
Does the Ford system display the current pressures (e.g. Corvette/GMs) or does it only go off when the pressure is out of spec? (e.g. Toyota)
Just my, .02..
Just my, .02..
Originally Posted by Davy Crockett
you can swap to new wheels by buying new bands at about 45.00 each ,,I have a pic but I can't remember how to get it here,,,,oh well
i was in the same boat with my sensors i found a place online that sells new bands and cradles. they are like $17.00 a lot cheaper than the one from ford.
www.americanmuscle.com
they told me that they would work so im going to try it. the guy that is putting my wheels on has a girlfriend that works a ford she talked to her tech and they said that all you had to do was switch the sensor over. i was told by another place that they just used a bunch of hose clamps when they change them over. i will have the bands in a few days and will post the results
Here be the link....yo!
Over 4K miles with no issues.
https://www.f150online.com/forums/sh...highlight=TPMS
