How the F%$# do you get the front rotors off a 4x4???
Old 10-31-2005, 06:59 PM
mrinaldi's Avatar
Ok...Here's the deal....2000 F150 4x4 Off road 5.4....146k, time to do the brakes again....Last time I did them I only replaced the pads figuring the next time I do them, I will need to replace the front rotors...So here we are...I removed the wheel, caliper, and caliper bracket....As far as I know, the rotor should come off now????????? I have been pounding on it with a small sledge hammer for an hour, and it hasnt budged,,,,And this is still the first one, and my nerves are shot.....Am I missing something.....Somebody please help.....
Old 10-31-2005, 07:26 PM
Quintin's Avatar
Keep swinging. They can be a bear sometimes. Worst case, you can cut a slit in the rotor and use a big cold chisel to try to crack it in two, but I've never had to go that far. Then again, I don't live in a rustbelt state either.
Old 10-31-2005, 09:05 PM
Kool Aid's Avatar
Spray some penetrating oil, or WD-40 around the hub and let it soak awhile.
Then, start beating on it while spinning the disc.
It will come off, eventually.
Old 10-31-2005, 09:08 PM
sporkdevil's Avatar
Alright, it's a 4x4, but my 4x2 I needed to remove that nut under the dustcap. This may be pointless, but you don't happen to have that do you? If you do, try that
Old 10-31-2005, 09:09 PM
lees99f150's Avatar
Try hitting it between the studs on the face. this should break it loose. Use a BFH.
Old 10-31-2005, 09:10 PM
lees99f150's Avatar
On a 4x4 the rotor slides on the hub over the studs. on a 4x2 the rotor is the hub.
Old 11-01-2005, 12:42 AM
mrinaldi's Avatar
Thanks guys......I didnt give up and finally got it, both sides....So tonight my baby got new rotors, pads, new sway bar links(the pass. side was gone so I replaced both of them), WD 40'd the crap out of everything underneath upfront, new plugs, new coil packs, and new injectors, just got back from driving it around for an hour or so...It really feels like new again....Im a happy camper....
Old 11-01-2005, 08:40 AM
dpostman's Avatar
I went through the same process a few months ago. Started politely with a Dead Blow Rubber HAmmer, then upgraded to a small 4lb sledge hammer, pounded for about 15 minutes per side. Finally it came off.
I did clean off the hubs really good and put on a thin layer of anti-seize compound before putting on the new Rotors, hoping that if I have to go through this again, there won't be so much banging goin'on
Dpostman
Old 11-01-2005, 09:59 AM
yysenhimer's Avatar
I told you last night Mike....you needed a "Ford Wrench".
Old 11-01-2005, 10:09 AM
rutherk1's Avatar
That wont cut it. You need a sledge. We did rotors on a friends expedition with about the same mileage. We hit the rotors so hard they came off in pieces. Make sure, when you put the new ones on, you put some gold grease or some other kind of anti-sieze between the hub and rotor.
Good luck.
Old 11-01-2005, 04:19 PM
wetanner's Avatar
An air hammer workes great too!
Old 11-01-2005, 05:12 PM
lees99f150's Avatar
You can use a "blue tip wrench" also
Old 11-01-2005, 07:35 PM
desparado's Avatar
Hah! I used the search just like you always preach, and found 2 other references to the "blue tip wrench", none of which clearly explains this mystery tool I "torched" this site looking for the "flaming" answer, and still can't figure it out. That just "burns" me, "hot" damn! I'm just gonna have to raise the "heat" and "fire" this question at you: What is a "blue tip wrench"? I know, I know...I overdid it
Old 11-01-2005, 11:43 PM
racerf150man's Avatar
cutting torch just a lil it will weaken them and nail them with an air hammer or sledge
Old 11-02-2005, 11:53 AM
desparado's Avatar
Originally Posted by desparado
"torched" this site "flaming" answer, "burns" me, "hot" damn! raise the "heat" and "fire" this question
Yeah, I kinda figured that out. I was KIDDING!
Quick Reply: How the F%$# do you get the front rotors off a 4x4???
