5.4 won't run under load
Mass air Flow sensor and the idle air control. Go to the index in the Articles and How To section and look under the Engine sub section, you will find articles that will help you.
Also, did you change the pulley size? If so, you may need a custom tune for that.
Best-case, dry the motor - compressed air.
Worst-case, you've compromised one or more COPS (coil-on-plug). Which usually means replacement.
Water also tends to collect under the boots in the plug wells, depending on how much water pressure was used.
MGD
MGD
