need help.
need help.
hi guys i'm in a little bind here. i have an 04 f150 nbs with the 5.4. my pedal position sensor is having glitches when its cold out and the truck is cold. i had the dealer order it they said there was 1 left and it was in california. well 2 weeks later i never got it and they said that the inventory was wrong and there are none left and the company that made the part went bankrupt
so uhhh....... what now? i can find them aftermarket for an 07 but nothing for an 04 or 05. can i use one from an 07? i have the adjustable pedals.
i woulda thought i could at least get the drive by wire parts with the issues they're having. and i know i can get used parts but i figured if i can get new i will. is there any differences in the 07 pedal sensor that anybody knows of? possibly install an 07 pedal and harness connector? i dont have a problem going used if i have to but i'd definately like to go new.
I may be a little late but I just checked Rockauto site and they have the 2004 adjustable pedal connector but didn't show the sensor. You may want to give them a call. They might have one or know where you can get one. http://www.rockauto.com/catalog/rafr...-partdescribe2
didnt even think about that, thak you. i'll call them monday. yea i can find the connectors all day long but not the sensor itself. and i looked on alldata for specs of an 04 vs. 07 and the sensors themselves have different resistance values, so i now know an 07 sensor wont work.
Ok Dorman has the part. I searched this site and found a sensor it indicates is for your 2004 truck. Here is the site.
http://www.autopartsexpress.com/rese...2&ctt_nwtype=e
They have an 800 number as well. good luck
not real sure on the 5.4 but i do know in 07 ford switched tb's to top it off the whole upper intake, 07-10 4.6 2v tb have a all in one, the motor and tps is built together, to my knowing the 04-06 have a spetrate sensors.
Before replacing
Disassemble and clean the snap-fit electrical connection just before the pedal. The Manufacturer of the connection reported problems in the original design 2004-2006 MY (Model Year). Use electrical cleaner on both halves and re-seat.
