1st time ever 98 F150 won't start
Started it this morning to back it out of the garage. Tried to start a few hour later and all I get is a loud click. Lights all work fine. Tried jumping it but still just a loud click. Replaced the battery two years ago and the alternator 3 years ago so I know it isn't teither of those.
Raining cats and dogs right now but when it stops I'll check for ground wire connection. Can a starter just go out all at once? Never had a problem starting from day one.
Thanks,
Ron
Thanks,
Ron
Thanks,
Ron
Thanks,
Ron
My situation happened when I had to be at a wedding 10 miles away that day. Thank God it started the second time. My mechanic told me to change the starter to be safe.
I just went out and played around with it and all wires are connected and not corroded so it's not that. I think the sound is more like a mufled clunk coming from the firewall area,if that makes any sense. Still can't understand how something just dies all of a sudden.
Ron
Ron
i had a similar issue with my 98 exploder 5.0. never had a starting issue. Started it one saturday morning went to the gas station and it wouldn't restart. Had to sit in the freakin gas station lot dropping the started. There's a little ground strap on the started that had fallen apart. Corrosion got the best of it.
Ford starters last a long long time. My guess is its the firewall relay the one right next to the battery. Short the big post to the small post with the key in the on position if it starts your problem is the relay.
Ron
did you short the posts? could be a connection I would take all battery cable off and clean them on both sides on the engine connect side to. Check the starter cables especially they corrode pretty bad especially in snow areas.. road salt.. Be careful taking the connector bolts off on the starter The corrode and break. Especially on one that old..
Ron
mileage is kind of irrelevant when it come to corrosion. The truck is going on 13 years old..
Yea, it's most likely just the wires down low. I've never had a Ford starter go out, -but I broke enough of them. Glad theirs a lifetime warranty, - They updated the starters a couple years ago, -Via TSB. They all come pig tailed in the box, - that's so you won't need a 10mm to install it
Seriously, - it's so Bosch isn't throwing you another starter every other year.
_____________
Do you have a meter ? You can check continuity real quick. -
Measure the resistance between the starter relay to starter solenoid positive cable.
If resistance is less than 5 ohms, - replace starter relay.
If not, replace the circuit in question.
.Seriously, - it's so Bosch isn't throwing you another starter every other year.
_____________
Problem fixed with a new starter. The wiring coming out of the starter was completely corroded off. Bought a rebuilt one and she purrs like a kitten again. I have to say that the top bolt was the hardest to get out seeing it was in the blind. Per normal, it went back together much faster then taking it out.
Thanks to everyone for the comments/suggestions!
Ron
Ron
