Weird noise coming from engine
I have a noise coming from the engine and can't seem to locate the problem. It is kind of a whining/humming noise and increases with acceleration. Probably a better description is it sounds like something is rubbing. I have checked the belt and its not rubbing anything. This just has me really puzzled and any help would be greatly appreciated. Thanks.
x2. Probably a pulley. Alternator or tensioner. Could even be a noisy (burnt fluid) power steering pump. These fords have theyre own sound to them which we all know so well. But after some old nasty fluid.. They can get noisy.
Remove the belt and run the truck for 30 seconds or so and give it a few revs. See if its gone. If it is, check all the pulleys for even the slightest noise, they should also spin smoothly.
