Won't Start
Old May 16, 2010 | 11:55 PM
fritz4077's Avatar
The guy i got the harness from said the wires that where all spliced where used for an electric start up..i guess that makes sense would that affect the no start up
Old May 16, 2010 | 11:56 PM
fritz4077's Avatar
ok cool how does one reset it just a button?
Old May 17, 2010 | 12:01 AM
Toyz's Avatar
I'm not sure how that works but I would imagine it had to override the PATS system. Which in turn.. I guess if something was missing or removed and not put back when the harness what swapped out could affect it. Someone more familiar with remote starts/ PATS system will have to clear that up.
Old May 17, 2010 | 12:05 AM
fritz4077's Avatar
i got a pats tune on my sct that a tuner made up for me and my truck...
Old May 17, 2010 | 05:41 PM
fritz4077's Avatar
ok i took pics of the spliced wires and here is what i came up with...the one red wire is sodered with the red and yellow strip wire that connects onto the engine wire harness.... then the blue wire that is spliced is ran all the way to the driver side and was connected into the part of the harness that runs to the rear of the truck...
Old May 17, 2010 | 05:43 PM
fritz4077's Avatar
now for the two random plugs..the one round with red top is a 2 pin and the one is a black with green strip just in case you cant see it
Old May 17, 2010 | 05:50 PM
Toyz's Avatar
Dear baby jesus.. Please help this man in his trials as he sifts through the wreckage of wires in which I have never seen such carnage.
HOly macKaroni bro. The spliced wires go beyond the mysterious extra plugs. I see a whole pool of connectors near the air filter and soldered exposed joints near the battery firewall. Man. Where did the red male end that was near the filter go?I still don't know what the others are.. I'm looking though
Wait... whered the pic go that was near the filter with all the yellow twist connectors...?
Old May 17, 2010 | 06:14 PM
Toyz's Avatar
What color are the 2 wires going into that plug? And is it on the passenger firewall near the solenoid on the firewall? If so, maybe its this one..
Thats the only round 2 pin connector I can find on the passenger side. Theres one more but much smaller down on the inner fender trim. I cant find anything square with a brown end like the other one. Nor do I see any on the drivers side but 2, one goes to the MAF and the other sits right under the filter.. not sure what it goes to.
Old May 17, 2010 | 06:37 PM
fritz4077's Avatar
no its not that one i already got that connected that goes to the alternator...the colors of that plug r the red with yellow stripe..and black with green stripe
Old May 17, 2010 | 06:46 PM
jbrew's Avatar
Found Red/yellow strip.
Still looking for the rest. You sure this is a 5.4L harness ? It is right, - what year ?
Old May 17, 2010 | 06:48 PM
jbrew's Avatar
I'm thinking Black/LG is a ground, since I haven't looked at grounds yet.
Old May 17, 2010 | 07:00 PM
jbrew's Avatar
Could it be Black/ yellow stripe ? That's for the AC.
Old May 17, 2010 | 07:06 PM
jbrew's Avatar
No wonder I couldn't find it - Black /light green = heater circuit -
Old May 17, 2010 | 07:23 PM
jbrew's Avatar
Soooo, that's your AC recharge connector. Connects directly to the recharge post by the window washer box.
You haven't posted wire color on the others, - can't help there and you need to tell me what harness, - that would help as well.
Old May 17, 2010 | 07:56 PM
fritz4077's Avatar
thats weird because the A/C is connected is already connected...this plug is right near the firewall..and i am asking what year it came out of...i already looked at all the fuses and it has all the lightning fuses such as inter cooler pump and all that stuff
