Won't Start
Old May 17, 2010 | 11:10 PM
  #31
fritz4077's Avatar
the guy said it came out of an 2002 lightning
Old May 18, 2010 | 07:12 AM
  #32
jbrew's Avatar
Originally Posted by fritz4077
thats weird because the A/C is connected is already connected...this plug is right near the firewall..and i am asking what year it came out of...i already looked at all the fuses and it has all the lightning fuses such as inter cooler pump and all that stuff
Then it plugs into your AC accumulator.
Old May 18, 2010 | 08:33 AM
  #33
jbrew's Avatar
Yea, that's right,- Brown cover = Accumulator. That's back by the firewall / passenger side.
Old May 18, 2010 | 11:24 AM
  #34
fritz4077's Avatar
ok cool and do u have any thoughts about what all them random wires that are spliced go to....the guy said it was for an electric start if that makes sense
Old May 18, 2010 | 02:57 PM
  #35
jbrew's Avatar
Yea, that might be, but usually most remote start wiring is done under the dash. Sounds and looks like he rigged it. I guess from here, I would check the starting circuit. There's some communication that takes place before the PCM gives the okay to start.
Here's something different on the lightning harness -
Have you noticed any gauge sweeping or "PAT's" light flashing. She won't fire with the theft light flashing.
Old May 18, 2010 | 03:28 PM
  #36
jbrew's Avatar
Ignition System
The ignition system consists of the:
crankshaft position sensor (CKP sensor) (6C315)
camshaft position sensor (CMP sensor) (6B288)
spark plug
The ignition system is:
a coil on plug (COP) ignition system controlled by an electronic engine control (EEC) integrated into the powertrain control module.
set for base timing at 10 degrees before top dead center (BTDC) and is not adjustable.
Old May 18, 2010 | 06:07 PM
  #37
fritz4077's Avatar
i got a tune to turn off the pats and its loaded on the truck....do you think any of these wires could prevent my truck from firing up
Old May 18, 2010 | 06:12 PM
  #38
jbrew's Avatar
I would have to know what all those other wires in your pics are tied to. You don't say. Those aren't Ford wires so I have no way of tracing. You have to follow to splice, then post color and stripe.
Old May 18, 2010 | 06:33 PM
  #39
fritz4077's Avatar
ok i will go do that right now
Old May 18, 2010 | 06:42 PM
  #40
fritz4077's Avatar
the red wire connects to the red and yellow stripe on the harness...the green goes to nothing it is cut off and the blue runs to the drivers side and was connected to the rear harness...is there any chance a relay could be bad or something just a thought
Old May 18, 2010 | 07:02 PM
  #41
jbrew's Avatar
Yea, that red yellow is a hot wire = hot all the time most likely, that's not holding things up as far as "Crank no start" . The others, yea- without knowing/seeing the splice , factory color, your guess is good as mine.
Did you compare harnesses to see if anything is different ?
Is she getting spark? If so, she should fire with a little gas. Have you tried to knock it down to just a fuel problem?
Also, you can't continually crank the engine for more than 4 seconds at a time. The PCM shuts the injectors down when you hit 5 seconds. Just keep that in mind and I don't know how long the reset is on that once you do.
Old May 18, 2010 | 11:15 PM
  #42
fritz4077's Avatar
yes i am getting spark and the pump works i hear it turn on every time i turn the key....i did use the 5.4L harness that runs to the rear of the truck and spliced that and connected the wires there are a few wires left over....one is red on the harness that runs to the back and i have to check tomorrow to see what ones arent connected...Mike told me to do this
Old May 18, 2010 | 11:21 PM
  #43
fritz4077's Avatar
is there anything i could put in the fuel to give it some pep or something or is all that stuff bad for the motor i have always herd mixed thoughts
Old May 18, 2010 | 11:24 PM
  #44
Toyz's Avatar
Think the gas is bad?
How long did your truck sit during the swap.
I would think it would still run, just like crap.
Old May 19, 2010 | 10:31 AM
  #45
fritz4077's Avatar
it sat for 7 months
