Knocking sound..
Old Apr 17, 2010 | 08:08 PM
Please take the CAPS LOCK off.
Old Apr 17, 2010 | 09:26 PM
DYNOTECH's Avatar
Originally Posted by DRKNSIDE
GUYS I JUST HAD TO REPLACE MY CAM PHASERS AND A FEW OTHER THINGS DURING THE PROCESS BUT WHAT I DONT GET IS THAT EVERY PERSON WHO HAS HAD CAM PHASER PROBLEMS WITH THE TRUCK HAS HAD AT LEAST 60000 MILES ON THERE VEHICLE MINE HAS 23481 I CANT BELIEVE THAT THESE WOULD GO OUT SO SOON, BY THE WAY IT COST ME NOTHING TO REPLACE EVERYTHING BUT TO MY AFTERMARKET WARRANTY IT COST AROUND 2000 BUCKS. I KNOW ALOT OF OTHER PEOPLE HAVE BEEN HAVING THE SAME PROBLEM WITH THERES JUST WANTED TO SHARE WHAT I HAVE HAD TO GO THROUGH, THANKS! BY THE WAY SHE IS STILL IN THE SHOP WHICH REALLY SUCKS! BUT I GET HER OUT TODAY!!
Are they failing causing drivability issues or are they just making noise? There is a difference. Granted no one likes a noise but just a noise is not a indicator of mechanical or pending mechanical failure on these.
Old Apr 17, 2010 | 09:28 PM
DYNOTECH's Avatar
What happened glc did you have to remove your reading glasses?
Old Apr 18, 2010 | 12:14 AM
DRKNSIDE's Avatar
please take the caps lock off.
does it bother you!! Lol!!!
Old Apr 18, 2010 | 04:13 AM
Forum etiquette considers it to be SHOUTING.
Old Apr 18, 2010 | 07:00 AM
westtnfx4's Avatar
I can't say this enuff....5w30 motorcraft semi synthetic and ALWAYS use a motorcraft oil filter.....I've learned from experience.
Old Apr 18, 2010 | 02:15 PM
5w20 is the recommended grade.
Old Apr 19, 2010 | 10:57 AM
bdenglund's Avatar
There seem to be no power loss issues related to the knock. I cant tell any difference in drive ability. But the knock is very obvious. But like i stated before, for only around 15 seconds. As far as the oil issue.. i believe my manual states to use 5w30. And I will be switching to motor craft filters on the next oil change. But im still gonna stay away from synthetics with my mileage..
Thanks everyone
Old Apr 19, 2010 | 12:00 PM
westtnfx4's Avatar
I would only use 5w20 in northern climates....or the north pole Down south where it's hot most of the year 5w30 works perfect.
Old Apr 19, 2010 | 05:50 PM
Use what you want, but Ford has updated the specs, and 5w20 is now the recommended grade in all Tritons and 4.2's. I know your manual says 5w30, but that has been superseded.
