egr nipple into the manifold
Old Mar 25, 2010 | 03:13 PM
ultradowny's Avatar
I got a 2000 f150 4.6 v8 and my lower egr tube nut rusted right off. I have a new egr tube and nipple that goes into the manifold but does anyone know if that nipple is a part of the manifold itself on the 2000 model or will it just take some hard work to get that nipple out of the manifold?
Thanks!
Old Mar 25, 2010 | 05:05 PM
Toyz's Avatar
I'm not sure about the 4.6L but on the 5.4L the nipple is threaded into the manifold. Should come out. Not sure how bad yours rusted out but doesn't sound like it will hold a wrench very well if its that brittle. Might just take some time, try heat it up with a torch and soak it in pb blaster before your first try to turn it. Don't start a fire though
If its the same as the 5.4L like this
It is threaded into the manifold
Old Mar 25, 2010 | 08:43 PM
ultradowny's Avatar
Thanks Toyz,
It looks exactly like that, but upon closer inspection and feel it seemed like she was just welded on there. The lower egr nut that screws into the nipple was just rusted right out and the threads on the nipple where the nut screws into were so heavily worn from corrosion that there was no thread left. What i did for a fix until i can get some more time is wrap a lead sheet around the joint and put a high heat sealer in it with 2 screw clamps to create as much of a seal as i can. Anyone think thats a really bad no no?
I should take pictures and post em.
Old Mar 25, 2010 | 09:58 PM
chrmar's Avatar
All I've done is wrap some stiff wire around the EGR tube and around the manifold, pulled tight and wrapped some more. Works good!
Old Mar 26, 2010 | 06:22 AM
ultradowny's Avatar
Good to hear, thank you
Old Apr 2, 2010 | 08:00 AM
ultradowny's Avatar
Just as a note, im an idiot! I dont know why i didnt think of this at the time, but lead has a low melting point, I wokeup this morning to go check underneath the truck and saw melted metal, then i remembered heat + lead dont mix. Onto plan B
Old Apr 2, 2010 | 01:28 PM
Toyz's Avatar
ooOO, didn't even catch that lol. Hope none got down into your cat.
Junk yard should have some manifolds for around $20, might be better just to replace it.
Old Apr 3, 2010 | 07:13 AM
600Polaris's Avatar
i took some furnace cement, aluminum tape and hose clamps, put a little cement on the tape wrapped the tube, wrapped it with just the aluminum tape and then tightened two hose clamps around it and it hasn't opened up in three years and i planned on getting a new one but my fix is working well enough. don't get any cement in your egr tho, you probably dont even need it, i just thought it would be more air tight. it smells funny for a few days tho
its a little tight for mechanics wire and a twister, so i used hose clamps, but that tape has not melted yet.
Old Apr 5, 2010 | 08:50 AM
ultradowny's Avatar
with the egr tube not connected would that set my check engine soon to come on? I read that there is a sensor that reads the egr stuff, am i right?
Old Apr 6, 2010 | 04:06 PM
AZTriton's Avatar
I think it would trigger the CEL to come on and spit out a code. Is yours not connected and not spitting out a code?
Old Apr 19, 2010 | 06:35 PM
ultradowny's Avatar
Havent got it hooked up to a computer yet, i have a new problem with it (broken spark plug) which may be a connected problem
Old Apr 19, 2010 | 10:16 PM
Toyz's Avatar
Broken plug? You sure its not a stripped plug....?
