I am an IDIOT!!!!
Old Aug 7, 2009 | 12:36 AM
  #31
markho's Avatar
Originally Posted by jbrew
Wait, you have an 01 , shouldn't matter, but I have a vid of an 01 as well lol -
http://picasaweb.google.com/jbrew393...84705673453298
Is that normal? Not sure if mine does that. What should it do normally? The wiz kid mechanic around the corner looked at my oil pressure gauge and said it looked good.
Old Aug 7, 2009 | 12:38 AM
  #32
markho's Avatar
Originally Posted by Shane1
Markho in one of your posts you said your muffler fell off. Do you have a muffler on there right now? It sounds like an exhaust leak or a rod. Oil PSI should be checked.
No muffler on there. I planned on it being the last thing to fix after all this is over. My neighbor who is a wiz and a ford enthusiast thinks it could be the rod bearings, but still suggests to get it to a dealership for their diagnosis. He was showing me an engine block from a mustang. He said it was ford's hardest metal used in blocks. He proceeded to show me how to change the crankshaft bearings. Looked easier than the lash adjuster job i pulled off.
Old Aug 7, 2009 | 12:54 AM
  #33
jbrew's Avatar
Yea that's normal @ cold start on both trucks running a Motorcraft oil filter or one with an anti drain back valve. If you run a Fram filter in one of these, - it's a slow death, that's why their called the "Orange can of death" lol.
The guage is more of just an idiot gauge and not a very good one, but it shows reaction time. - how fast the pump builds pressure.
Like Shane1 said, you can get a true oil pressure test. I've also heard exhaust leaks sound like an internal problem as well. I have to say, that does sound like a rod to me. Can't say for sure from here.
Old Aug 7, 2009 | 08:30 AM
  #34
markho's Avatar
I don't have a motocraft filter on it, but I did purchase one. When the noise first appeared I went and got an oil change with Rotella in hand. I also had a quart of lucas . The mech at the exxon station was like "I have something heavier for poor *** sombitches like you." The oil weight was like 50w. So I have the 50w, lucas oil, and a no-name filter in there, but understand it is not the original cause of the noise. It was a response to it. It did quiet it down somewhat. I'm going to drain her and change the oil filter today.
Old Aug 7, 2009 | 12:35 PM
  #35
ONELOWF's Avatar
LOL. Another Einstein at a gas station..... lash adjusters are designed to work with multi vis oils - 5w30 - 10w30 - it is critical. I would drain it real good and follow the instruction given here for further diagnosis.
Old Aug 7, 2009 | 01:35 PM
  #36
jbrew's Avatar
Exactly.
Mannn, unbelievable lol
Here's another good quote. This ones from Labnerd -
"The Triton engines need oil fast at the cams and that's why the spec calls for a 5w oil for cold start up."
_________________
You HAVE TO run a good oil filter. - Motorcraft, WIX, Napa Gold (examples) which are most likley the more common good ones.
_________________
You might want to visit this site first before trying anything, -or if your unsure about something. These guys really know there stuff around here.
BTW- I wouldn't use any additives. I would want to flush it personally, -then run a blend, but. Welll , try the right stuff first and see what happens.
Old Aug 7, 2009 | 01:52 PM
  #37
Norm's Avatar
My noise happens when the motor gets warm. Would the timing chain do that?
Yes especially if you are running 50W oil. It will take a while to get where it needs to go and the chain tensioner is hydraulic.
Old Aug 7, 2009 | 08:42 PM
  #38
markho's Avatar
crap I got 5w-20 motocraft. is this still okay?
Old Aug 7, 2009 | 08:43 PM
  #39
jbrew's Avatar
That's actually the recommended weight from the manufacturer for your model.
Old Aug 7, 2009 | 11:40 PM
  #40
markho's Avatar
i exchanged 2 gallons of rotella for a gallon and a quart of motocraft at autozone. they had a special, 2 bucks more got you a mc filter. Too bad i paid 8 bucks for one last week at the dealer, did i mention I was an idiot?
Old Aug 8, 2009 | 01:16 AM
  #41
markho's Avatar
This might be a clue, might not. Hows your pressure gauge react from cold start to warm ?
Here's a 98 -
http://picasaweb.google.com/jbrew393...90121627213570
acts pretty much the same as in the video.
Old Aug 8, 2009 | 01:55 AM
  #42
jbrew's Avatar
Well, hopefully it will be alright once you get the right stuff in thier.
Good Luck
Old Aug 8, 2009 | 09:28 AM
  #43
markho's Avatar
Good Luck
i need some of that...updates later.
Old Aug 8, 2009 | 09:39 AM
  #44
ONELOWF's Avatar
Really? My sticker on the radiator cover says 5w30 - 98 4.6????
Old Aug 8, 2009 | 10:06 AM
  #45
PhqChevys's Avatar
I'd say cam phasers.
