It must be true love
No one can ever doubt how much i love my f-150 after spending 22 hrs removeing all 8 broken spark plugs. First 5 came out with the glue the pin in the extracter kit from snap on but the last 3 the loc tite would not take, i think it has something to do with the fact the first 5 had the electrode stay in with the porcelin ( removed with looooong skinny pliers) but the last 3 the electrode came out with the hex i think it was fouled inbetween the electrode and porcelin. So i went shopping and found the lisle kit that pushes the porcelin down enough to thread the sheild and extract. so all in all
$135 for lisle kit
borrowed snap on kit
94$ for plugs
and a weekend of my life i will never get back
Still cheaper than the dealer
but i do love my truck
$135 for lisle kit
94$ for plugs
wow.... in that time I could have
taken my intake off
changed each plug, taking sips of iced tea in between each
Compression tested each cylinder
cleaned threads
took a nap
washed the cat
installed newly gapped plugs
ported the intake
painted it lime green for added HP
wake up next morning and take my time putting it all back together... LOLZZZ
What is the deal with the 3V plugs? I hear they are a 2 piece design???
taken my intake off
cleaned threads
took a nap
washed the cat
ported the intake
i followed it to a "T" even had motorcraft brand carb cleaner didnt matter how many times i went back an forth probley 3 dozen times with each one they still pulled apart i have taken plugs out of other fords (v10) they creak and squeak but still come out mine didnt even creak i guess that might be a the tell tale sign if the creek and squeak as your turning them out your probley ok but if theres no noise look out
The kit Matco has works even better than the ones that Ford sent us. Last time I changed plugs, I said **** it and used my 3/8 impact (after breaking them loose first). Only one that broke was #8 and I couldn't get the impact back there real good. I think the "impacting" from the gun actually helps. It's like this, either they break, or they don't. Might as well try it.
