Oil level at lower hash marks after only 5000 miles?
Old 09-04-2008, 05:14 PM
wreedKR's Avatar
I changed my oil about 5000 miles ago with 7qts of Royal Purple 5w-20 and a Motorcraft OE filter. Checking the oil today the level is already at the lower end of the hash marks. Is this normal for these engines?
Just curious, this is my first 5.4l.
Old 09-04-2008, 05:18 PM
risupercrewman's Avatar
My 2007 5.4 consumed 1/2 a quart at 3000 Miles running Mobil-1 5w-20, I suppose it's normal.......I make a habit of checking my oil every 2 weeks or so.
Old 09-04-2008, 05:22 PM
wreedKR's Avatar
How much is a 1/2 in relation to the hash marks on the dipstick?
Old 09-04-2008, 06:29 PM
scotyg's Avatar
i thought you 5.4s only took like 5 quarts, or maybe it was 6. but i know 7 has go to be too much.
Old 09-04-2008, 06:30 PM
wreedKR's Avatar
Nope 7qts according to manual and workshop manual and fleet.ford.com
Old 09-04-2008, 06:53 PM
Quintin's Avatar
Yes, that's normal and nothing to be worried about.
Old 09-04-2008, 07:05 PM
wreedKR's Avatar
Well I guess why I worried is I was planning to go to 10000 miles change intervals with the Royal Purple, if I continue at this rate it will be extremely low, correct? Or does it only consume the oil and then stop at some point?
Sorry for the "stupid" questions. lol
Old 09-04-2008, 07:45 PM
tucker27's Avatar
No u should always never let it fall under lower hash line.
Old 09-04-2008, 07:46 PM
wreedKR's Avatar
So if I want to go the longer interval, I just need to top it off? How much oil will bring it up to the upper part of the hash marks?
Old 09-04-2008, 08:22 PM
If you doing extended change intervals, & using Royal Purple, you still have to pull the DipStick from time to time & check your oil.........
Old 09-04-2008, 08:27 PM
f150fella08's Avatar
yea the old f150s take 6 and the 04-06 take either 6 or 7 (6 is at the middle mark on the hash and 7 is at the top) and after that (the square air filters, not the round ones) take 7
Old 09-04-2008, 08:31 PM
2004+ 5.4 3v's take 7 Quarts exactly.............
Old 09-04-2008, 08:32 PM
wreedKR's Avatar
I understand now I need to know how much I need to add. How much of the dip stick is equal to 1/2qt or 1qt?
Old 09-04-2008, 08:33 PM
wreedKR's Avatar
Also the oil was still golden brown, I assume this is still good clean oil?
Old 09-04-2008, 08:53 PM
every 2004-2006 ive changed the oil in ive always put 6 and its right in the middle
Quick Reply: Oil level at lower hash marks after only 5000 miles?
