NewTSB on spark plug removal
Old Nov 5, 2012 | 11:56 PM
  #166
bootsmckiber's Avatar
Sorry,I'm not all that computer savvy.
Old Nov 24, 2012 | 07:36 PM
  #167
falco13's Avatar
ok, so everyone is talking about these Champion one piece plugs, but the Champion website says they don't have a product for this engine! HELP! does anyone know anything or maybe have part numbers for the Champion one piece plugs? also, are they even worth the trouble of finding, or should I just stick with the stocks and the nickle anti-seize?
Old Nov 24, 2012 | 07:49 PM
  #168
So how many success stories with the hot engine & impact removal method do we have going on? Just looking to hear if it has been working out well.
add me to the list
https://www.f150online.com/forums/v8...ess-8-8-a.html
Old Nov 24, 2012 | 10:01 PM
  #169
Stick with Motorcraft, but if you must use Champions, the # is 7989. COP boot replacement required.
Old Nov 25, 2012 | 11:03 AM
  #170
Irish FX4's Avatar
Stick with Motorcraft and a little bit of anti-seize.
Old Nov 27, 2012 | 06:32 PM
  #171
falco13's Avatar
Thanks yall
Old Dec 4, 2012 | 08:57 PM
  #172
Streak143's Avatar
Count me into that 8 for 8 group. My recipe was a bit of luck coupled with the dealer carbon cleanout about 5K before the change. A quick shot or two of PB Blaster in the spark plug well for about 10 minutes or so to help break them loose, and then the old back and forth with the ratchet to work them out. Motorcraft Plugs and anti-sieze to finish it up.
Old Feb 28, 2013 | 08:18 PM
  #173
wheelentime's Avatar
Ok so I have the tool kit, just in case, and went to pull the first spark plug out this afternoon. only thing is, my 5/8 Spark plug socket didn't fit ????? so I use a 15mm deep socket, fit fine. Weird Right???? any thought to that? also When I unscrewed it, it wont come out all the way. I felt it completely unscrew. and was able to screw it all the way back in, and tighten it. but the spark plug wont come out of its hole. any thought to that?
Old Mar 5, 2013 | 03:43 PM
  #174
vet3138's Avatar
I assume you figured it out by now, but just in case you didn't the plug is broken. The threads have torn away from the shroud and are spinning around the ceramic, you need to snap the plug off so you can use your puller tool. I had one do this also.
Old Sep 10, 2013 | 08:55 PM
  #175
GJMORAN's Avatar
has this been remedied for the 2010+ model years?
Old Sep 10, 2013 | 09:29 PM
  #176
The heads were redesigned in the middle of the 2008 model year.
Old Sep 10, 2013 | 10:37 PM
  #177
GJMORAN's Avatar
is there anything to prove that? i just took my truck in to get some service done to it and they are claiming the spark plugs need to be replaced @ $650 + i think $40 per broken spark plug.. are they trying to squeeze me for more money?
Old Sep 11, 2013 | 12:21 AM
  #178
If you have a late 2008 or newer, they are trying to take you for a ride.
What year and engine do you have, and how many miles on it?
Old Sep 11, 2013 | 04:56 AM
  #179
digitaltrucker's Avatar
Started in 2008, If you have brown boots on your plugs you have the newer heads.
Black boots mean problems on 2008 and earlier.
Old Sep 11, 2013 | 05:03 AM
  #180
Yikes, where are you located? In Houston Texas the dealer I use charges (advertises) $289.95 for 8 cyl, which includes plugs.
Are you sure they are not adding in other things because of mileage like: radiator flush, injection cleaning, coil over ignition, fuel filter? just to name a few.
