NewTSB on spark plug removal
Old Sep 11, 2013 | 11:21 AM
  #181
GJMORAN's Avatar
i have a 2010 with 80k+ they said its just the plugs. i would like some ammo to fire back at them with so i can get this stuff done. basically just bought the truck 2 months ago and they are expecting me to pay this kind of money..it pisses me off
i am in southern california and i am dealing with the dealership cal worthington ford
Old Sep 11, 2013 | 12:32 PM
  #182
Which engine - 5.4 3 valve?
Those are relatively easy and are NOT subject to breakage. If the dealer wants to hose you like that, go find an independent shop. A plug change in that motor should be $300 TOPS and is well within the abilities of any independent shop that does spark plugs.
The revised heads use conventional 1 piece plugs without a ground sleeve. Trust me, ALL 4.6 and 5.4 3 valve engines in 09 and 10 use those.
Old Sep 11, 2013 | 12:45 PM
  #183
GJMORAN's Avatar
i got the 5.4L
Old Sep 13, 2013 | 12:52 PM
  #184
GJMORAN's Avatar
so theres no document or anything that i can take to the dealer to prove that they are wrong about breaking plugs off in the head?
Old Sep 13, 2013 | 01:08 PM
  #185
There is no document. They are trying to rip you off. They would know your truck uses one piece plugs. Buy one and take it to them. Tell them to shoot straight with you. That plug change should be less than $300. If they won't do it free under a warranty from your purchase, I would get out of there and take it elsewhere.
Sent from my iPhone using IB AutoGroup
Old Sep 13, 2013 | 01:17 PM
  #186
jbrew's Avatar
is there anything to prove that? i just took my truck in to get some service done to it and they are claiming the spark plugs need to be replaced @ $650 + i think $40 per broken spark plug.. are they trying to squeeze me for more money?
If a Ford dealer is telling you this, Call the Ford Customer service line. You can look that number up, - might be in your users guide in the glove box.
Yea, they shouldn't have an authorized service center if they no THAT little about your truck.
They know better, it's next to impossible not to.
Def, trying to scam you, - no doubt...
Old Sep 13, 2013 | 01:27 PM
  #187
jbrew's Avatar
That's enough BS to make you want to do it yourself, - or learn how to IMO.
Old Sep 17, 2013 | 06:37 PM
  #188
Stonehedge's Avatar
Did my plug change on my 2006 F-150 HD with 65K miles. I followed the usual tips from here and it took me about 10 hours over 2 days and I broke 4 plugs. The lisle tool did its job. What a PITA!
Old Sep 23, 2013 | 02:26 PM
  #189
GJMORAN's Avatar
talked to 2 dealers in the area and they are both quoting around the same price and saying the same thing about the spark plugs being a p.i.t.a. and having a tendency to break off in the head. am i surrounded by crooks?
Old Sep 23, 2013 | 02:43 PM
  #190
They are all idiots if they don't know that you have the revised heads with conventional 1 piece plugs.
Old Sep 6, 2014 | 11:31 AM
  #191
E_Net_Rider's Avatar
has this been remedied for the 2010+ model years?
Ford needs to be forced to fix for all years and I mean a true fix, if it means replacing all heads.
NO BS fix allowwed. Plugs can leave you dead on a winding road, no place to pull off and then it is your life.
Plugs back out, you are dead. Misfiring dead engine, you are dead. Dirt, water getting into spark plug well, you are dead. Ford is no better than GM.
Old Sep 6, 2014 | 11:34 AM
  #192
The first one you dealt with was the one you bought from and his name is Ford.
Old Sep 6, 2014 | 11:39 AM
  #193
Originally Posted by digitaltrucker
Started in 2008, If you have brown boots on your plugs you have the newer heads.
Black boots mean problems on 2008 and earlier.
Unless they redesigned the boots on 4.6 since at least 2002, that is another piece of junk.
Water or even fine dust such as pollen gets down in the spark plug well. Ford should be forced to redesign and recall all this junk they created.
Old Sep 6, 2014 | 11:46 AM
  #194
Originally Posted by sam1947
They already have.......they re-designed the heads....end of story for Ford. Ford will not re-design a part for an older model as a TSB has been issued as well as many other 'fixes' are out there. Unless it's a safety related item, there will also be NO recall for the plug breakage. Bad design= YES, but, it's something we will have to deal with. On a side note, waiting for 125K miles to replace these plugs is asking for trouble anyway.
Plugs were supposed to last 100K. Found On Road Dead would not only apply to vehicle but you because of dangers when that happens.
So it is a safety item and Ford should be forced to fix all existing vehicles and repay everyone who did it out of pocket. A minimum payment should be required for anyone that prove ownership during a likely needed plug and something such as title showing mileage should be enough.
(PS, I'm just tired of garbage being foisted upon the educated. And tired of govment agencies not doing their jobs.)
Old Sep 6, 2014 | 11:49 AM
  #195
Originally Posted by bootsmckiber
Sorry for my ignorance but whats a TSB,?and is that the 500$ fix the Ford dealer is talking about
TSB is a piece of paper that is too stiff to use for you know what. TSB's were meant to be helpful, not an excuse for incompetence coming from engineers. The line needs to be redrawn or move toward buying anything without Detroit name.
