Champion Develops "FIX" Plug for 5.4L 3 valves!
Old Mar 22, 2008 | 09:05 PM
  #226
risupercrewman's Avatar
Sounds like the FoMoCo has all of us bent over without any KY!.......
Old Mar 22, 2008 | 09:18 PM
  #227
FordTech1's Avatar
I tell myself that everyday dude, trust me......
Old Mar 22, 2008 | 09:25 PM
  #228
That's funny!...........
Old Mar 24, 2008 | 08:17 AM
  #229
dkstone05's Avatar
Well guys my truck is at the dealer right now getting the plugs changed out to the new Champions. I gapped them this weekend to about .052. One thing I noticed while gapping you have to be very careful not to touch the electrode tip or the platinum section on the ground strap. They both look very fragile and could easily tear them up. So you must have a tool to grab the back side of the ground strap and adjust the gap that way.
I almost feel like asking for prayers. I'll post up later tonight on how the change goes and how it runs after I load my Troyer tunes.
Old Mar 24, 2008 | 04:42 PM
  #230
I will bow my head & pray for you & have a moment of peace!......
Old Mar 24, 2008 | 09:40 PM
  #231
dkstone05's Avatar
Well I have bad news and good news.
Bad news is that the dealer broke 3 of the plugs. They were able to get them out using the rotunda tool though. I was kind of surprised that they broke, truck being an 05 with 35k miles and pretty much only used Shell gas. Although a lot of the miles are from my short 12 mile stop and go trips to and from work. But at least the dealer stood by their word that if any did break they would not charge me anything extra.
Now on to the Champions. The dealer thought I was nuts for wanting to install them but they did say that "if" is helps solve this problem they don't blame me for trying. So far I've only put about 25 miles on them, about 12 miles on the stock tune and the rest with Troyer 92 oct perf tune. So far the truck runs Exactly the same as before. The only spark knock that I have is after I loaded the custom tunes and is very very minimal and only at hight RPMs and nearly WOT. I also had this same spark knock the first time I loaded the tunes several months ago. This should go away once I get a few drive cycles on the tunes.
So really if I didn't they were changed I would have no idea anything is different. We'll have to see what happens as the mileage increases. So far I give them a big
Old Mar 24, 2008 | 10:57 PM
  #232
RoushF150's Avatar
I just pulled the trigger and had the dealer replace mine. It's $210 for the plug replacement and $50 per broken plug. Whether they break or not will tell me what my issues will be in the future.
I figure my odds of getting the plugs replaced for less than $500 are pretty good.
Roushcharged 2005 with 35000 miles.
Old Mar 25, 2008 | 05:57 AM
  #233
Geeshh! I am suprised that some broke with that low mileage!.....
Old Mar 25, 2008 | 01:07 PM
  #234
RoushF150's Avatar
Welp,
I just heard back from the dealer. All 8 plugs came out without fail. Get those plugs replaced sooner than later folks.
Old Mar 25, 2008 | 01:33 PM
  #235
tomclem's Avatar
Roush150,
Did you go back with the Motorcraft plugs? Is so, do you know which one(heat range) they used?
Old Mar 25, 2008 | 03:06 PM
  #236
RoushF150's Avatar
Originally Posted by tomclem
Roush150,
Same plugs as stock. Same heat range. Not sure the number. I'll get that for you.
I'm going to be changing mine myself at 70K miles. Hopefully by then we'll have enough information on how well the single piece ones work.
Old Mar 26, 2008 | 09:20 AM
  #237
Ed753's Avatar
Originally Posted by dkstone05
Does anyone have any ideas about what gap we should run? I saw on sparkplugs.com list the Autolites for a .045 gap but this champion at a .054 gap. I have tried getting a hold of Champion/Federal Mogul but it always say all lines busy call back later. My Champions are gapped at .045, like DVD_FX4, I just don't know if I should increase the gap or not. I know that no one is going to have a definate answer but what would your bet guess be?
I'm thinking I might just leave them the way they are and see what happens.
I don't think that .054 is right, no reason to stray that far from OE specs.
Old Mar 26, 2008 | 10:19 AM
  #238
dkstone05's Avatar
Sparkplugs.com has these listed at the .054. I gapped them at .051 but the tech that put them was gone for the day and they couldn't tell me if he gapped them differently. It this point I really don't care what they are gapped cause they are running good.
Old Mar 26, 2008 | 12:13 PM
  #239
FordTech1's Avatar
Our online shop manuals have been updated...this is for an 05 5.4 3valve
Spark plug PZT-14F
Spark plug gap (not adjustable) 1.15 ± 0.13 mm (0.040 to 0.050 in )
The PZT 14F's weren't listed a few weeks back, it still had the old number in there.....
Old Mar 26, 2008 | 12:45 PM
  #240
dkstone05's Avatar
Spark plug PZT-14F
Good info there. They said that the tech that did mine check the gap but did not know if he adjusted it or not. I would assume he did and probably followed the manual even though it is a different plug. If he did not not a .051" is pretty close to that range and doubt it would make much of a difference. If I get really bored this weekend I might pull one of the front plugs just to see where they are at but I'm going to have to be really bored before that happens.
