Temp gauge
Old Nov 13, 2007 | 07:08 PM
  #31
jbrew's Avatar
Plug ? Last I checked we were talking about heater hoses - I dunno how it went to plugs?
Old Nov 13, 2007 | 07:21 PM
  #32
MGDfan's Avatar
"Plug hole"
And no - I ain't goin' there
From Autometer:
Look at the drivers side of the engine block, from underneath the
vehicle. Below the last freeze plug there will be a threaded in
adapter.
If it requires an allen wrench to remove, it is then a standard
3/8"NPT
If it requires a box end wrench or socket to remove, it is then a 16mm
x1.5 thread size and if you are installing an electric gauge, you may
use an Autometer #2268 adapter.
LINK to pix: https://www.f150online.com/forums/sh...d.php?t=308358
Old Nov 13, 2007 | 07:27 PM
  #33
Tumba's Avatar
thanks fan i was getting worried
Old Nov 13, 2007 | 08:04 PM
  #34
jbrew's Avatar
Yup!! That's where the block heater is .. I think the newer models are still in the same location.
Old Nov 13, 2007 | 08:24 PM
  #35
NYfordguy's Avatar
OK this thing comes with adapters so I'd use the adapter that has the 3/8 NPT thread....super!
Old Nov 13, 2007 | 11:02 PM
  #36
built54's Avatar
yep it goes right in!
  #37
NYfordguy's Avatar
Awesome thanks bud!
Old Nov 14, 2007 | 07:35 PM
  #38
NYfordguy's Avatar
Hey guys, i crawled under the truck today and only could find the where the block heater is plugged in. Am i missing something or is that the hole, where the heater is that i am going to use?
Old Nov 14, 2007 | 07:53 PM
  #39
built54's Avatar
well we dont know where your heater is going in at
Old Nov 15, 2007 | 12:14 AM
  #40
NYfordguy's Avatar
Drivers side below the manifold about...oh i dunno 5 inches i guess would be a good estimate.
Old Nov 15, 2007 | 04:37 PM
  #41
NYfordguy's Avatar
bump
Old Nov 15, 2007 | 09:42 PM
  #42
Tumba's Avatar
Originally Posted by B-Man
On my '04 5.4L it is on the driver's side, towards the rear.
it should be on the cylender outside on tha drivers side toward the rear.
It will be maybe 3 to 5 " above where the oilpan bolts on the bottom of the block.
is that what you're asking?
Old Nov 15, 2007 | 09:50 PM
  #43
NYfordguy's Avatar
Well i found where my block heater is attached to the engine would this be near it? I also have the 4.6L
Old Nov 16, 2007 | 08:39 PM
  #44
NYfordguy's Avatar
bump
Old Nov 16, 2007 | 08:58 PM
  #45
built54's Avatar
we dont know where your block heater is going in, do yo usee that picture that b-man posted?
