Temp gauge
Old Nov 12, 2007 | 12:31 PM
NYfordguy's Avatar
Temp gauge
Hey folks I got an electric Phantom Autometer temp gauge. I've read where to install the sensor unit (inlet hose to heater core) via this pic: https://www.f150online.com/galleries...5516&anum=8198
But that engine is different that mine and its a 4.6L I think is a 2001 too. Anyways, My heater hose connections to the engine are way in the back near the firewall, 1 connection is really far back and the other is somewhat higher and closer to the front, does anyone know which is the inlet hose? And also what size barbed fittings would fit that? 5/8"?
Thank you!
Old Nov 12, 2007 | 02:49 PM
jbrew's Avatar
Do you see the Aluminum stem sprouting up towards the rear passenger side of the manifold ? That's your return..
A steel line runs from behind your water pump on top of the block, real close to the knock sensor and then angles up behind the passenger side head - you can barly see the hose clamp on that one in the pic - look close and you'll see the clamp.. Anyway , that's the inlet hose.
Keep in mind that hose also has a Solid Brass reducer inside that protects the heater core from pressure damage - make sure you incorperate that with the new setup..
Good Luck
Old Nov 12, 2007 | 07:07 PM
NYfordguy's Avatar
Oh ok so the one that is easier to see and get at is the return line, great! That figures lol.
Now this reducer you speak of, is that incorporated thorough the entire inlet hose or just at the point where the hose and inlet connect?
Old Nov 12, 2007 | 07:15 PM
built54's Avatar
why do that? I put mine in place of the plug down on the back drivers side of the block.
Old Nov 12, 2007 | 07:49 PM
NYfordguy's Avatar
The freeze plug or another plug? That sounds easier but do i have to drain my coolant to do this or can I be quick about it?
Old Nov 12, 2007 | 09:15 PM
built54's Avatar
i did it very fast, only lost a small puddle worth. Its right next to a freeze plug, it takes a 3/8" drive from a ratchet to get it out
Old Nov 12, 2007 | 09:26 PM
NYfordguy's Avatar
OK this may change things I have a engine block heater, did this replace the freeze plug or is the freeze plug in a diff. location than the heater hookup?
Old Nov 12, 2007 | 09:29 PM
built54's Avatar
usually those replace a freeze plug, so you can still use the place i mentioned
Old Nov 12, 2007 | 09:57 PM
NYfordguy's Avatar
Perfect thank you sir! Much easier than chopping the heater hose up.
Old Nov 12, 2007 | 09:59 PM
B-Man's Avatar
Originally Posted by jbrew
...<Snip> Keep in mind that hose also has a Solid Brass reducer inside that protects the heater core from pressure damage - make sure you incorperate that with the new setup...<Snip>
How does a reducer lower pressure in a hydraulic system ?
I could see it reducing flow, but not pressure ??
No flame, just want to understand...
Old Nov 12, 2007 | 10:05 PM
B-Man's Avatar
On my '04 5.4L it is on the driver's side, towards the rear.
Old Nov 12, 2007 | 10:07 PM
built54's Avatar
thats where I said mine was, thanks for the pic
Old Nov 12, 2007 | 10:18 PM
NYfordguy's Avatar
Perfect thank you!!!!!!!!!!!!
Old Nov 12, 2007 | 10:55 PM
Tumba's Avatar
reduced flow going in . norestriction going out to pump pulling water
less pressure
Old Nov 12, 2007 | 11:26 PM
NYfordguy's Avatar
Another question that i just thought of. What is the thread size on the plug for the sensor that i will be removing?
