Project GO FAST is now in progress!!!
Old Sep 30, 2007 | 11:52 PM
  #106
jbrew's Avatar
Originally Posted by built54
I think ill check that tomorrow, but I have the tuner idle set at 980 in neutral, and i can get it to idle at 500, and 860 in drive, which actually idles at about 550-600, but it will die when i come to a stop if i dont touch the gas. I know its nothing serious, the engine runs smooth as can be, and has great oil pressure, im still happy
With that description it sounds like the IAC - typical IAC problem .. Can you set the tuner idle down any farther. You might be outside of parameters with that setting. - Normal settings 750 I believe..I'm not sure , but if your outside the margine , it might not know what to do.
Old Sep 30, 2007 | 11:56 PM
  #107
built54's Avatar
hmm yeah i can, but i just turned it way up hoping it would idle... maybe now that i changed the wiring harness, ill reinstall my tune and set the idle in the low 700 range... ill try that b4 work, if its good, ill drive it to work, I really really want to.
Old Sep 30, 2007 | 11:58 PM
  #108
stopper's Avatar
sweet
i like the idea of reloading the tune or a stuck IAC, especially if it sat for a long time before being used.
did you ever go through with the 2wd swap or is it still 4x4? haha if you had 4x4 high on and hammered it off a stop, you could launch forward and really suprise people
Old Sep 30, 2007 | 11:59 PM
  #109
jbrew's Avatar
I prolly couldn't resist either way
Old Oct 1, 2007 | 12:01 AM
  #110
built54's Avatar
its 2x4 now, but I'm watching a set of 4.10s for the front, which im going to install when I get this whole thing fixed, no big deal, 4x4 would be very nice in the rain.
Old Oct 1, 2007 | 12:04 AM
  #111
SKRWZ's Avatar
If that engine was in my truck I couldn't wait to go "HEMI HUNTING" here HEMI HEMI HEMI HEMI .....
Nice work so far Joe just take your time and it will all fall into place
  #112
jbrew's Avatar
HEMI HUNTING Could be ( :
Yea I just replace my IAC a few weeks ago - replaced everthing on the TB and elbow - even the throttle body . It ran rough at idle - I was just telling this to someone else in another thread - My truck always idles smooth , never had a problem. But yea, it ran rough @ idle , it was jumpy . Well it fixed itself, I'm pretty sure it was the new IAC.
Old Oct 1, 2007 | 12:06 AM
  #113
built54's Avatar
yea ill check that out tomorrow, thanks guys, im out for the night!
Old Oct 1, 2007 | 12:18 AM
  #114
Faster150's Avatar
sounds like the MAF isnt plugged in and doing idle seek. couple be damaged wiring harness from sounds of ur descriptions. i was was around i could make u a new harness in about a day. since its one of my jobs at work in doing wiring harness finding breaks and fixing them on bigcommercial vacume clean out trucks. hope u figure it out man!
Old Oct 1, 2007 | 12:23 AM
  #115
SlammaJamma's Avatar
What you doing for Exhaust?
Old Oct 1, 2007 | 03:18 AM
  #116
jbrew's Avatar
I was talking with Faster150 earlier - said he set his at 1100rpms @ idle thru the tuner and the motor idled as programmed - So I'm thinking it is indeed the IAC that's at fault here and your tuner settings should idle the motor to what you have set.
IAC's prolly just stuck from not being used, like "stopper" suggested above - Shoot , were yours is located , it's easy enough to get to real quick before work.. I would pull it off and with a small pair of needle nose pliers, maybe hemostats or a screwdriver would even work (careful with the screwdriver in there) - But with a little WD40, work the mechanicals inside the IAC a few times - make sure everthings moving in there - compressed air will force the lubricant into the right places - throw it back on, see if she idles..If not - the lightning set up must be so much different that you'll need to go another route.
Good Luck ..
Old Oct 1, 2007 | 03:50 AM
  #117
Kevin24's Avatar
That whine sounds aweaome
I agree with the IAC being messed up,mine did the same thing,let off the gas and it would die instantly.Is it off your motor or the take-off??
Headlights coming on with running lights,i dunno cheack for a loose ground.
Knock sensor do a search,tons of info from Bluegrass!!
It sounds like it's gonna fly Take it easy until you break it in!!!
Old Oct 1, 2007 | 08:23 AM
  #118
built54's Avatar
yeah the maf is plugged in, i didnt even touch that wiring harness. Ill check that iac after work, I need to pull the intake off and replace that knock sensor, and it would be easier if i didnt drive it today, as bad as I want to
Old Oct 1, 2007 | 08:36 AM
  #119
MGDfan's Avatar
Not so fast.
Lightnings don't use knock sensors - they may be present, but they are either not hooked up, and/or not enabled in the tune. Reason - the blower's mechanical transients are mistaken for knock and would cause the timiing to be pulled.
A look on the Lightning forum will confirm this - and it's one reason for spot-on tuning, fueling, A/F's and ample octane overhead - almost any detonation can be fatal because the PCM is out of that safety loop entirely.
Here's some info:
https://www.f150online.com/forums/sh...2&postcount=37
And posts 37 on up in BigTrucks' Lightning swap/buildup:
https://www.f150online.com/forums/sh...t=knock+sensor
My dumb guess here is it's the tunin' ....
Old Oct 1, 2007 | 08:54 AM
  #120
ONELOWF's Avatar
Originally Posted by MGDfan
Not so fast.
A look on the Lightning forum will confirm this - and it's one reason for spot-on tuning and ample octane overhead - almost any detonation can be fatal because the PCM is out of that safety loop entirely.
Deja vu - (sp) - Bigtruck311's thread - see post # 45 by WLF.
