Project GO FAST is now in progress!!!
Originally Posted by built54
yeah if it wasn't for the camera flash, you wouldn't see them. I still need to wire them to a switch, just had them connected temporarily.
Ok since this problem is still in question, i'll ask. I recently installed a bjh balancer, well a few days after I put it on, it started to make a ticking sound from up from, didnt think too much of it, well it got a little louder, so i thought maybe it came loose, which it did, I got it as tight as I could, and it still ticks. Nothing is loose or rubbing anything up there. I took the bolt back out and ran it back it, to see if the balancer was all the way on, and it was. still no luck. here is a vid clip of the noise, its louder than the vid makes it sound. the sound is coming from the dead center of the pulley.
I'd get it off of there before it damages the snout on your crank. I have a 351c that happened to had to rebuild the engine to fix it. put the old one or get another new one and replace it. dont want that thing wobbling on your crank.
