stripped iac bolts...
Originally Posted by masonball
I stripped the bolts holding the IAC. What do I need to remove to get to it easier? Take off the throttle body and everything behind it?
Yes you would pull the elbow where your TB bolts to the intake.Is it the lower bolt that you stripped or the upper bolt or both?Anyway you are going to have to pull it then drill and tap your holes.Or you could prob patch it up until you have more time
Originally Posted by Kevin24
WTF masonball
I would feel a little retarded too
Your going to have tuh take the TB elbow off so you can get at er..
This sounds like something Kevin would do
no, I wont have to tap the holes, I just stripped the heads.
Originally Posted by defective
Easy if it's just the head thats stripped. Hammer the next smaller SAE socket on there or use vise-grips. Another option is to saw or file a slot like a screwdriver on the bolt head.
Actually i am known to let strength get the best of me and snap the friggin bolts!!!
Ya, the head's still on there, I tried vice grips, even the small ones, and once they're clamped on, there's no room to move in any direction. My dad tried to pull a "vacuum" hose out of the way, but it ended up being a nice hot coolant line. Thanks dad, for the sticky green engine. Also, I can't hammer on a smaller socket - there's no room for ANYTHING back there. Once I have the TB off I can get them off.
Just cut the firwall out w/ sawzall or a plasma cutter
ya jbrew always happens when your about done
Then I have about 500 dull drill bits that I go thru before finding a sharp one
Gotta get me one of those "Drill Docter's " someday..
Well there's all kinds of different vise grips available. I have a dinky little needle nose pair that would probably work.
Did you try the socket? Maybe you can use some big plyers like channel locks to squeeze it on there. You can always break out a little file and shape it up a bit while taking it down a size.
Your just going to have to get creative or pull it out.
