Iginition COIL OVER PLUG '97 5.4L v8
Old Mar 20, 2006 | 08:58 AM
dreamsr's Avatar
Exclamation Iginition COIL OVER PLUG '97 5.4L v8
Can someone tell me the part number for the 1997 5.4L V8 iginition COP?
Old Mar 20, 2006 | 08:52 PM
temp1's Avatar
1997 - 2000 5.4L engines should all use the same COP. Here is a picture of my 1999.
F7TU-12A366-CD
1L2U-12A366-AA
Here is a link to a .pdf file that has some possible x-refs
http://www.mitechignition.com/pdf/pr...itechCoils.pdf
Old Mar 21, 2006 | 01:38 PM
dreamsr's Avatar
Cool Question
What's the difference between the two that you have shown me, did your truck come with both? Thanks!
Old Mar 21, 2006 | 01:48 PM
Johngs's Avatar
His only had the first one on it. But there are several different part numbers out there.
Old Mar 21, 2006 | 02:47 PM
dreamsr's Avatar
Question Why so many?
John what the difference between the respective types?
Old Mar 21, 2006 | 03:42 PM
Johngs's Avatar
I personally couldnt tell you for sure. I would suspect its just changes in the part number throughout the lift of the run, with no actual changes to the COPs...but thats just a guess
Old Mar 21, 2006 | 04:17 PM
Johngs's Avatar
If it helps any, here is one of the COPs off my truck:
Old Mar 21, 2006 | 06:40 PM
temp1's Avatar
The yellow one was replaced by the black one which was replaced by whatever is on the truck now. I lost the #4 cylinder COP twice because of the dreaded leak from a hose that is above it (its documented in a Ford TSB somewhere).
I think Ford makes engineering changes now and then and thats why the numbers are prefixed/suffixed differently. The core part number is the 12A366 but the part numbers can be different depending on the vendor (like the DG numbers).
OF-121 . . . . . . . Coil On Plug
FORD:
12LU-12A388-AA,
1L2Z-12092-AA,
F7TU-12A366-AB,BA
F7TZ-12029-AB, BA, CA, CC,
DG-467,
DG-481,
DG-491
Old Mar 22, 2006 | 09:44 AM
dreamsr's Avatar
Thumbs up Good to go
Thanks a million Temp!
