Which is better? K&N in my stock intake or replace w/ entire new K&N intake system?
I'm currently running the stock intake on my 1998 F150 4.6L with 203k miles on it. I use it for daily commuting and don't have the pedal to the floor much, I on occasion will tow a small landscaping trailer but normally don't. I've read a lot of the old posts in this forum, many seem to suggest replacing the stock intake with either an Airforce, Airaid, or K+N. I noticed in Walmart the other day they sell K+N filters that I can just drop into my stock intake. My old filter needs to go anyway, my only debate is whether I should just swap the filter to K+N or if I should swap out the whole intake system with the K+N FIPK tube etc.. Which is better? My main goal is fuel economy and I heard these help a little bit (I understand there are other mods that can help more though, but I'm on a budget). Is swapping the filter the same as swapping the whole intake tube system? Any opinions?
Thanks- Matt
Thanks- Matt
swapping out only the filter will not change the mpg noticably, the only good thing about swapping the filter i you will never have to buy another filter again, changing to the whole intake assemble is like $200 and will get you some more HP but will not change the MPG by more than .5 if even that much, it is pretty much up to you but it would take awile for the whole assembly to pay for itself in the fuel saving, good luck
on
In theory the less restrictive K&N filter will allow more air to flow to the engine. This extra air allows you to add more fuel. Adding more fuel will increase the power. Because you make more power at any given throttle setting you should be able to reduce the throttle setting to make the same power before the mod. This reduced throttle setting might save you some gas. Now if you beleive that and if you beleive that the FIPK is better than just the filter then you should get the FIPK. The only problem is that there is no way of knowing what, if any, the feul savings are.
Regards
JMC
Regards
JMC
It is according to how much you want to spend and what performance you are looking for. At Wal-Mart the filter itself is in the $40 dollar range I assume. You can get the whole intake itself for less than $300 on ebay.
Now the second thing is, with 200k miles on your engine, you probably wont improve gas mileage and power very significantly.
3rd thing. If you are going for looks, then I would suggest the Air Force 1 system. It has the stainless steel versus the plastic tube that the K&N has. I have the K&N and I am happy with it and the performance gains are similar with the AF1. But if you want better looking intake get the AF1.
3rd thing. If you are going for looks, then I would suggest the Air Force 1 system. It has the aircraft grade aluminum versus the plastic tube that the K&N has. I have the K&N and I am happy with it and the performance gains are similar with the AF1. But if you want better looking intake get the AF1.
Aluminum is just about the worst material for an intake, in terms of heat transfer to the intake charge. IAT temps actually drop a few degrees over stock whn using the AF1 under normal conditions, even lower than the plastics used in some other intakes. This was dug up using Search.
http://www.troyerperformance.com/cgi...atalogno=16408
Cheers
Grog
Originally Posted by MikefromMT
I've always liked the K-N except for the whole "pay $10-$15 for a recharge kit, wash, wait for it to dry, re-oil" they may be a lifetime filter but the cost/time is a hassle.
Thanks again,
Matt
Try this airbox mod
I have a k&N ($48) and modified the airbox using this tech. article. I love it
https://www.f150online.com/tech/airbox.html
