THE H.P FREAK'S "SUPER FREAK" 5.4 BUILD UP!! (pics)
Old Oct 8, 2006 | 12:26 AM
  #811
Faster150's Avatar
Originally Posted by Neal
HI!... Truck is most likely down till spring, 7 out of 8 cylinders is no good................
damn man that reall sux what happend? to lean? man i was really consitering going 5.4 but damn with all the problems your having i think ill stick 4.6
Old Oct 8, 2006 | 11:17 AM
  #812
stopper's Avatar
Time to build a V-10 and be done with it! Ditch that lemon 5.4
Old Oct 8, 2006 | 12:02 PM
  #813
JMC's Avatar
JMC
25 Year Member
Don't discount the 5.4 becasue of the ****ty luck Neal has been having. There a lot of 5.4 Tritons out there that are holding up just fine. Don't forget that Neal has an ON-OFF switch for a gas pedal.
Old Oct 8, 2006 | 12:48 PM
  #814
Faster150's Avatar
maybee it needs a regulator for it than lol
Old Oct 8, 2006 | 12:55 PM
  #815
built54's Avatar
Yeah, dont hold your thought of all 5.4's being like this... Look at the lightnings, sure some dont last, but there are some 600hp+ running daily. I would really like to know the story behind this neal! What the heck happened?
Old Oct 8, 2006 | 01:06 PM
  #816
Neal's Avatar
HI!... This link we explain the problems I've been having since last TUESDAY.
https://www.f150online.com/forums/sh...d.php?t=255952
I suspect that my old engine builder decided to cheap out and install the old piston rings back onto the 3 pistons that had to be replaced on the last half a$$ed rebuild he did. Compression was almost 160PSI across the board but #5 cylinder only has about 90-100PSI. I suspect it has been like this since I got it back from him the last time about 8 months ago. So basically I made 354RWH.P and ran a 13.60E.T on 7 cylinders..................
Old Oct 8, 2006 | 01:10 PM
  #817
JMC's Avatar
JMC
25 Year Member
The 160's was dry and the 90-100 was wet. It made about 30 psi dry....
JMC
Old Oct 8, 2006 | 01:25 PM
  #818
Bartak1's Avatar
Wow, that sucks.
I think if my engine man did that I would snap his neck like a twig...
Old Oct 8, 2006 | 01:27 PM
  #819
built54's Avatar
I would be going to a different engine builder, or just do it your self.
Old Oct 8, 2006 | 01:41 PM
  #820
Neal's Avatar
JMC
HI!... Actually it was 45PSI dry........... lol!
Old Oct 8, 2006 | 02:13 PM
  #821
Faster150's Avatar
45psi dry?? had that compression on my friends car.. the intake valve was burned up. have u bore scoped the heads?
Old Oct 8, 2006 | 02:24 PM
  #822
built54's Avatar
Hey Neal, what cc dish pistons were you running? Im thinking Mahle?
Old Oct 8, 2006 | 02:29 PM
  #823
built54's Avatar
I Just looked over it and noticed your running the same pistons and rods that are in my new engine. What did you say your compression ratio is? What ever that is, wouldnt I have the same then if i go with patriot stage II heads? Are the heads you chose any better?
Old Oct 8, 2006 | 03:09 PM
  #824
Bartak1's Avatar
Patriot heads are kind of bottom of the barrel, so to speak. Neal is running Fox Lake ported heads-one of the most common, and probably about the best, places for ported mod heads...
In short, Neals Fox Lake heads are heads and shoulders above Patriot...
Just to hold you over till Neal gets back to you, Im sure youll get a much better response from him
Old Oct 8, 2006 | 03:11 PM
  #825
built54's Avatar
Thanks.... Didn't know that. Where can I find these heads online? Cant seem to locate them on a search.
