Doing some maintenence, need some input
Ok, I plan on doing a some maintenace sometime soon and here is what I have planned-
motorcraft or bosch o2 sensors
Accel distributor packs
motorcraft fuel filter
motorcraft PCV valve
Plug wire
Maybe a new tranny filter and fluid, rear end oil, and a cooling system flush. Truck has 123k miles and im not sure if those things have ever been done. Not sure if i want to do them though.
Thats all I can think of so far, the more major schedueled maintenece stuff. Can anyone think of any other things? I put some Autolite platnum plugs in it about 6,000 miles ago so I shouldnt need new ones. Any Idea on what brand of plug wires to use. Motorcraft, Ford racing, Accell, Etc?
Also, if anyone had an idea of what any of the motorcraft things would cost that would be nice.
Plug wire
More stuff ...
Hi Bartak;
- Front O2's only, unless it's throwing codes. Bosch. AutoZone charged me $50.
- Drain the TC too.
- Bleed the brakes - replace with fresh brake fluid
- MC fuel filter cost me $20
- Hoses?
- air filter?
- belt(s)?
Cheers
- Drain the TC too.
- Hoses?
- air filter?
- belt(s)?
Cheers
i saw a post a few days ago with all kinds of cool pictures on cleaning the maf. you want to use electrical contact cleaner to clean the thing. the post very explicitly says to NOT use Q-tips, brake cleaner, or any other cleaner not intended for electrical circuits. i think the company that makes the electrical cleaner is crc. i found some at advance.
you can probably find the post pretty quickly with the search button.
-matt
-matt
